Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Motor calc program
Old 09-04-2009 | 06:48 PM
Default Motor calc program
HI
I am running a Hacker A50-16L being driven by Hyperion 8S 5000mAH cells through a Hacker Master 80Amp ESC on a 18 x 10 prop in my Wind S and I would like to get an idea of the Max current draw etc I can expect from this set up, Can anyone point me towards a Online Calc program I can use. All the ones I have tried so far have given me non sensical answers.
Mike
Old 09-05-2009 | 12:51 AM
tIANci's Avatar
Default RE: Motor calc program
Try this ... its not that accurate but so far its been close enough to work with ... [link=http://brantuas.com/ezcalc/dma1.asp]Motor Calculator[/link]
Old 09-07-2009 | 04:38 AM
Mike & tIANci
I tried this calc for my 6S / Scorpion 4025-12 / APC 17x10 setup and got an amp draw of just over 100, using the Scorpion motor calc this reduced to just over 85amps so you can get different results from different calculators.
John
Old 09-07-2009 | 05:19 AM
tIANci's Avatar
Guess its because of the data for the particular motor and also the prop ... for my DualSky motors I use their own software, that is pretty accurate, down to about 5% variation but I have yet to ever check the RPMs.
