Himax 6330-F3A Pattern Motor
#53
RE: Himax 6330-F3A Pattern Motor
Jim:
I'm testing one of the pre-production motor with MPI carbon fiber prop since last week.
APC 20.5x14 Turnigy 10S 5000mAh 20C LiPo, full charged:
5850 rpm max. at 65Amp
MPI carbon fiber prop 20.5x14, Turnigy 10S 5000mAh 20C LiPo, full charged:
6060 rpm max. at 65Amp, 5800 rpm at 62Amp
These values are pretty close to Kevin, Tom, Chris and Don's data.
Luke
Luke
#54
That might turn out to be a very good match. That is a good range for those props, my only concern would be can you still get in that neighborhood at the end of the flight.
I do like the idea that you shouldn't need to limit the throttle on the top end like we do on the Plettenberg and you will probably get better mileage due to the lower peak current.
Thanks for the research.
Jim
Jim
#55
Jim:
Here is the EagleTree data I collected on 3/14/10. This was running on a MPI 21x14 CF prop, TP4350 LiPo. One Master sequence usages was 3101 mAh. I had 4 flights on that day, average usage was 3228 mAh per Master sequence. About 6% lower than running on APC 21x14. The APC 21x14 is 109g, MPI CF 21x14 is 61g, that makes the difference.
BTW, I do not limit my throttle upper end (use ATV) after I updated my CC HV85 firmware from 2.18 to 3.20. In my opinion, it runs more smooth and response more linear. I have more than enough power through out whole Master sequence.
Luke
Luke
#59
My Feedback: (41)
ORIGINAL: lsjpeng
Jim:
Luke
Jim:
Luke
If so is there a link?
Thanks my motor will be here by Monday
Mike
#61
Mike:
The first production batch CF prop will be available in Toledo show as I was told. 21x14, 20.5x14 and 20x15 will be on top of the list. I don't have detail info about the retail price and schedule yet, but I heard that MPI will have an ad in the next issue K-Factor. Thanks!
Luke
Luke
#62
My Feedback: (90)
Received the motor yesterday. It looks very nice.
Since I plan to use it on a narrow body pattern ship (E-converted Sequel), I wonder if it makes sense to use a smaller APC E prop (such as 19 X 14) to cut down on capacity (and hence the weight) of the batteries.
ORIGINAL: nonstoprc
Luke
#66
My Feedback: (8)
I am at Toledo and had a long discussion yesterday with Jarvis at Himax (MPI). F3A Unlimited will be stocking this motor shortly and our web site will be updated with pricing as well this week.
Chris
Chris
#69
My Feedback: (50)
I ran my Himax 6330 for the first time Tuesday afternoon in my Intefral. I replaced a Pletty 30-10 EVO that is in Germany now repairing a bent shaft. (short landing due to battery cut off, broken CF prop, bent shaft) The Himax motor bolted in the same mounting holes and was an easy 5 minute install. I ran it with a CC 85HV esc and True RC 5000.
It was not a happy camper with the same ESC settings as the Pletty. Lots of bad noises as I advanced the throttle stick! I had to dial back the high throttle atv to 30-35% to get it to run at full throttle stick and the power was noticably down at that setting. Last night I got out the manual and changed the ESC to the recommended settings. Should have read the manual first. I'll try again tomorrow.
#70
ORIGINAL: burtona
Hope this helps.
Kevin
#71
I flew my new Himax 6360 yesterday and today. It replaced a Dualsky with LOTS of flights on it. No other changes, same ESC, batteries, settings. The new Himax was noticeably quieter and seems to have more midrange torque. Only 6 flights on it so far but right now I am very happy with it. Used roughly the same mah per flight as I used with the Dualsky but I would expect that to drop slightly as I learn how to throttle this motor. I seemed to be over throttling in some maneuvers because of what I perceive as a different torque curve. So far, so good. Now let's see if we can get a 1000 flights out of it. ;-)
Woodie
Woodie
#72
ORIGINAL: nonstoprc
There are four cooling washers coming with the motor. Is it required to install them as shown in the pic? thx
The X-mounting plate is an option. I bolted mine directly to the motor base.... no X-plate. This may save you ~20 grams.
Luke
#73
My Feedback: (90)
ORIGINAL: lsjpeng
Luke
ORIGINAL: nonstoprc
Luke
I could ignore the cooling washer, right?
#74
ORIGINAL: burtona
I tried firmware version 2.16 and 2.18, the motor squeal all the time. This also happened to Plett motor as well. You may find lots of discussion in this forum.
Castle Creations finally came out the new Firmware 3.20 that solved the squealing problem. The Himax's ESC settings are based on Dave Lockhart's recommandation. http://www.rcuniverse.com/forum/m_94..._1/key_/tm.htm post #17-20. Thanks!
Luke
