New Plettenberg F3A motor
#76
NY
RE: New Plettenberg F3A motor
Got in a few more flights recently with the best results obtained from the Falcon 20x13, when compared with the PT 20x13 and PT 20x12. The numbers were actually quite similar with the PT 20x12 and the Falcon 20x13. The PT 20x13 had significantly higher numbers and more battery consumption.
The high spike early in the graphed data is a full-throttle static run-up of about 3-4 seconds duration shortly before take-off. The static throttle-up pulled about 106 amps (also 4000 watts and over 7000 rpm!), but while flying the Advanced sequence the maximum amp draw was 85 amps tops and it was reasonably thrifty with battery consumption.
#77
NY
An interesting trend when looking at the multi-session view of the graph recorded with different props. Supports the earlier perception that the Falcon 20x13 is pretty good!
#79
ORIGINAL: nonstoprc
I wonder a PT 21X13 would be too much for the motor.
Henning
#80
ORIGINAL: Henning
I use both PT 21x13 and APC 21x13 with the Adcance but with a reduced throttle end point. I only use 80% power.
Henning
ORIGINAL: nonstoprc
Henning
The Advance does not have any problem with big props, the Evo 30-09 does.
#81
NY
Henning
Henning
Now that I know the maximum output I can start scaling it down a bit.
#82
NY
However, I am wondering, is there any gained efficiency (or other advantages) by using a bigger prop at a reduced power setting?
#83
ORIGINAL: cmoulder
What is the maximum wattage at that setting, and rpm as well?
Henning
Henning
Max readings: 3000 W and 85A static with top charged Hyperion CX10S 5000 mAh 25C. I have no RPM readings. The amps will start decreasing slowly. I have not done the measurement with the APC but the consumption in the air is more or less the same. The PT is slightly louder. I normally use 3200mAh on a P13 flying big and “fast†by European standard.
Henning
#84
My Feedback: (90)
Thanks. I have the Advance and it sounds like the motor is quita capable of handling pt 21x13. The motor is in the box as i am debating whether it is more powerful than the Neu f3a.
I once tested the pt21x13 on Neu f3a and was not quite happy about the top pull. As a comparison, the apc 20.5x13 is more capable of delivering the punch.
If anybody has first hand experiences running these two motors, please share.
#85
NY
The APC shape, blade width and pitch - a lot more of each at the root of the blade compared to PT - might be better.
The Falcons are carbon fiber APC clones so it isn't surprising that they perform similarly... even better at approximately half the weight! Or less than 1/3 the weight with the V2 Falcons weighing in at 37 grams!!
#87
ORIGINAL: nonstoprc
#89
NY
ORIGINAL: Derek.Koopowitz
Bob,
I'm using a Falcon 21x14 prop with my Advance - 74amps on the ground at 6200 rpm at full throttle.
Bob,
#94
Just received my Plettenberg Advance motor and was somewhat surprised when I weighed it. 601 grams including prop bolt/nut and washer, no bullet connectors. I was expecting the 565gr as advertised. Even removing the prop bolt/nut and washer it is 582gr. Anyone else notice this? So much for the couple ounces I was expecting to save over my current motor setup.
I have flown planes with the Advance motor in them and the motor is powerful, quiet and runs cool. Just somewhat surprised at this delta over advertised weight.
Woodie
Woodie
#95
Woodie, my advance with prop washer, nut etc also weights just over 600g, same as yours. So it does seem to be a little heavier than the advertised weight, but is a great motor non the less.
Regards
Clint
Regards
Clint
#96
Thanks Clint, I also contacted a couple of my friends with Advance motors and they had the same 600gr total. I can see no way to get the Advance weight down to 565gr even removing the wires, unfortunate. On the other hand, everyone I have spoken with about the Advance has been very happy.
Woodie
Woodie
#97
NY
Not sure if they changed this at some point, but Plettenberg advertises 595g on their site. I wonder if the 565 was an early guess rather than the actual. Either way you can add me to the long list of folks that love this motor
[link=http://www.plettenberg-motoren.com/german/Motoren/Brushless/Advance30/Masse.htm]Data for Advance 30-10[/link]
Joe
Joe
#98
Joe, could be a recent change and you could probably get the weight down to 595 by clipping the motor lead wires shorter. I went by what was published by Plettenberg on their description of the motor here:
http://www.plettenberg-motoren.com/g...ce30/motor.htm which states 565g
I have no doubt of it being a good motor, and this is not a big deal, just a disappointment based on my expectations.
Woodie
Woodie
#99
ORIGINAL: woodie
I have no doubt if being a good motor, and this is not a big deal, just a disappointment based on my expectations.
Woodie
Woodie
Think of it this way, you're getting more for your money....
Cheers,
Jason.
#100
My Feedback: (26)
ORIGINAL: woodie
Woodie
Woodie
