Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
 Is there a good plane for this power combo? >
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 03-31-2010 | 08:36 PM
Jetdesign's Avatar
My Feedback: (8)
Default Is there a good plane for this power combo?
I have a Turnigy SK3536-1400 550W motor, Turnigy Plush 60A ESC, and some Turnigy 3S 3600mah battery packs. I got them for a 'testor' plane so I can practice with electric stuff before plugging in the Sebart.
Is there a little pattern plane that will benefit from this setup? Here are some links:
[link=http://hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=7073]motor[/link]
[link=http://hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=9505&Product_Name=Turnig y_3600mAh_3S_30C_Lipo_Pack]battery[/link]
[link=http://hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=2166]ESC[/link]
Thanks!
Old 03-31-2010 | 09:43 PM
Default RE: Is there a good plane for this power combo?
The 3D Hobby Shop Aspera may work.  It is a good flying plane. You will be at the bottom of the range power wise, but if you build it light  it will be OK.
http://www.3dhobbyshop.com/detail.aspx?ID=2421
Old 03-31-2010 | 09:53 PM
faulknej's Avatar
My Feedback: (9)
What about the Sequence?
Old 04-01-2010 | 02:13 AM
Velco's Avatar
If you still can get it somewhere then Fliton Element 30. On many sites it was declared as a winner among sub 50" F3A. But I suggest getting a different motor 3548-900kV or 36-12xl both on 13x8
Old 04-01-2010 | 10:30 AM
cdodom's Avatar
The 48" Vanquish from extreme flight might be a good fit for the combo. I don't really know that much about electric but It was just my guess.
Old 04-01-2010 | 12:43 PM
Jetdesign's Avatar
My Feedback: (8)
ORIGINAL: Velco
If you still can get it somewhere then Fliton Element 30. On many sites it was declared as a winner among sub 50'' F3A. But I suggest getting a different motor 3548-900kV or 36-12xl both on 13x8
This is too funny. Just ran up my first power system test and found out I got the wrong motor! I ordered the 35-48 900kv before I even read this post
Old 04-02-2010 | 02:49 AM
Velco's Avatar
Well, sometimes also Murphy has to take a day off (with his laws) .</p>
Just to correct my previous post, not 12XL but 10XL which has the same kV of 900.</p>
Velco</p>
