Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
 Good cheap ESC, are there any? >
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 04-08-2010 | 05:52 PM
My Feedback: (12)
Default Good cheap ESC, are there any?
I am looking for a reliable and inexpensive ESC. Who makes one? Are the Turnigy ones from HK any good?
Old 04-08-2010 | 06:24 PM
Jetdesign's Avatar
My Feedback: (8)
Default RE: Good cheap ESC, are there any?
Phoenix ICE from Tower is a really good deal. Not the cheapest in the world but an amazing value with great support.
Old 04-08-2010 | 06:34 PM
My Feedback: (12)
that's more than I want to spend if I can help it, also it says it's only good for 8S
thanks
Old 04-10-2010 | 05:53 AM
Chris Moon's Avatar
My Feedback: (8)
The Castle ICE 80HV is good to 12S and is probably the least expensive way to go unless you are willing to try the Hobby King stuff. I don't have any feedback from anyone using the HK ones with 10S high amp set ups.
Old 04-10-2010 | 06:47 AM
My Feedback: (12)
thanks, I've heard nothing but good things about Castle stuff, so if I can't find a Turnigy or HK one that someone recommends then that's what I'll get
Old 04-10-2010 | 07:25 AM
Since no one else has tried one, I just ordered one of these and I'll let you know how the bench test goes in a few weeks.
[link=http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9130]TURNIGY K-Force 70A-HV OPTO Brushless ESC[/link]
At $69.99 its definitely a bargain price [X(]
Old 04-10-2010 | 08:13 AM
Jetdesign's Avatar
My Feedback: (8)
ORIGINAL: 2Sunny
You are awesome
Old 04-16-2010 | 01:33 PM
2Sunny, do you recived the ESC ?
Waiting for impressions and test results.
Old 04-16-2010 | 04:36 PM
Just one fellow's experience(me), but the cheap esc, and to a lesser extent,the cheap motor, route, for F3A electrics, don't work out too cheap in the medium-to-long term.
I started out with a cheapish far east ESC, which failed on flight one,due to the high current draw of the hotter of the two then-popular Dualsky F3A motors.
I then used the CC 85HV ESC ,which coped fairly well with the Dualskys, until one of the Dualskys burnt out, and took the CC 85HV with it.
Since then,I've had literally hundreds of trouble-free flights, along with many more useful extra facilities,offered by the initially more expensive jeti spin 99 ESC,and its jeti box companion thingy.
This has been with the AXI F3A motor.... a bit on the heavy side, and relatively noisy IMO, but powerful and reliable, for me at least.
Also I have used a couple of the Plettenberg 30-10 evo motors,(most used of all), and they have been superlative in any respect you could think of,except for the initial cost.
But over two or three seasons,cost per flight, the jeti/pletty combo has been easily the cheapest,I'd guess....
Again just my experience, but where you can save(and this is becoming more so each month almost) is with the cheaper battery packs now available.
Provided you can afford up to about four ounces extra weight, I've found that my Rhino 4900 5sx2 F3A packs are slightly more powerful,with slightly higher residual voltage, than my "generation 3" (latest ) Hyperion 5sx2 5000 F3A packs,at about one third of the price.
Moreover,both the Rhinos and the Hyperions, are well ahead of my original Flightpower F3A packs, in terms of keeping low IR numbers, and in terms of numbers of schedule-capable cycles before deterioration.
Old 04-16-2010 | 07:18 PM
I would not try the Turnigy if I were you. I tried the 100 HV and it lasted 17 flights befor it smoked(I was pulling 69 amps through it)
