Help for the new guy
Hi everyone,
I'm going to start flying some pattern contests next year, when I looked in the swap shop I didn't see anything interesting, so I began an exhaustive ten minute search and found the Wind 110 at a hobby shop in Grants Pass, Oregon. They recommend a Hacker A50-16L motor with a Phoenix 100 ICE ESC, which brings me to my question: Is that a good place for me to start ? This is my first trip to the electron side so I know nothing about whats going on over here, and it looks like I would get away with a $1000-$1300 investment depending on what I can use from my store of servos and things. I don't want to start a brand war, so please don't do that to me, I can order the three major pieces nice and easy peasy and get started assembling. However, if someone here in the Southwest has a plane in the 100ish size they have been thinking about letting go, I would be interested in hearing from you too. I've been practicing the Sportsman sequence with my 40% Comp-arf and I don't know if thats going to be a help or not when I get a true pattern plane. Oh, don't panic, I would never take the 40%'er to a pattern contest. Thanks for you input, Randy |
RE: Help for the new guy
Randy,
The Wind 110 is a great place to start. There are a few of them down here in San Diego, and I have flown them often. It is more than enough to get started in pattern, and will be fine all the way up to Advanced. I have never flown one with the stock setup, but if it is an 8S setup, it should be fine. Pattern planes a very sensitive to servo quality. Not sure what you have in your servo stores, but use the best you can, don't go cheap on servos. Learning the electric World is not that hard, and there are many people in the area with experience that will be willing to help. Again, don't go too cheap on the charger. Since you will be flying two four cells in series, a quality charger that is able to charge, and balance, two packs at a time will greatly enhance your electric experience. I know you won't, but a 40% would be allowed to fly Sportsman. LOL! Steve |
Randy,
I fly the Wind 110 with the A56-16 L on 8S 5000 packs. I buy the cheap packs from Hobby King and they work great. Bear in mind you'll be using 2x4S packs wired in parallel for an 8S pack. Depending on how long you like your individual flights to be you can get away with 4000 mah packs. Oh, I also use an APC 18x12 prop. The Ice 100 will work fine but I like Jeti Spin controllers better better than Castle Creations controllers with outrunner motors like the Hacker A50. Mike<br type="_moz"/> |
Thanks for the replys Steve and Mike.
Mike, you say you use a A56 motor, I looked at the Hacker motors in the Aero-Models site and didn't see it. Is it a more powerful motor than the A50 ? I assumed that just because of the higher number. I have to learn about motors and batteries so please enlighten me. I'm a firm believer in having some horse power in the bank, you can always throttle down, but you can't throttle up once you have the pedal to the metal. I fly at the same field as one of the top pilots (I don't want to drop his name), but he flies his sequence then immediatly lands. I suppose when I get there I'll probably do the same. Well, now that I think about it, landing is part of the sequence, DUH, my flights will be in the 7 minute range, plus or minus, I'm guessing. As far as batteries and chargers go, I've been buying from A123 Racing here in Santa Ana, California, he always knows what I need. But, I'm certainly open to new ideas. Being new to electrics, when you recommend or even mention your favorites, if you could give me a website that would be very helpful. |
ORIGINAL: Mike Wiz Randy, I fly the Wind 110 with the A56-16 L on 8S 5000 packs. I buy the cheap packs from Hobby King and they work great. Bear in mind you'll be using 2x4S packs wired in parallel for an 8S pack. Depending on how long you like your individual flights to be you can get away with 4000 mah packs. Oh, I also use an APC 18x12 prop. The Ice 100 will work fine but I like Jeti Spin controllers better better than Castle Creations controllers with outrunner motors like the Hacker A50. Mike<br type="_moz" /> |
Parallel... serial... What's the differnce? Just kidding. http://www.rcuniverse.com/forum/js/f...wink_smile.gif Good catch. That could have caused him a real problem.
ORIGINAL: 1bwana1 ORIGINAL: Mike Wiz Randy, I fly the Wind 110 with the A56-16 L on 8S 5000 packs. I buy the cheap packs from Hobby King and they work great. Bear in mind you'll be using 2x4S packs wired in parallel for an 8S pack. Depending on how long you like your individual flights to be you can get away with 4000 mah packs. Oh, I also use an APC 18x12 prop. The Ice 100 will work fine but I like Jeti Spin controllers better better than Castle Creations controllers with outrunner motors like the Hacker A50. Mike |
I think the A56 part is a typo. The A50 is very popular for the Wind 110. Another option if you want to go cheaper and want to get started is the Wind S 50e. I have one and I really flies nice. Not a lot smaller than the 110, but flies very nice as well. The Wind 110 is its own design, it is not a scaled down Wind S pro, whereas the 50e is a scaled down Wind S Pro and flies very nice. You can run the smaller and cheaper setup with the A50, 16S, and a 6S setup and it is a rocket ship if you want it to be. I have one and on a calm day it flies very similar to my 2m version. The Wind 110 is very nice also, but just more expensive. It is a little larger and heavier, so it does handle winds a little better. I don't think you can go wrong with either setup.
Arch |
ORIGINAL: desertrider49 Mike, you say you use a A56 motor, I looked at the Hacker motors in the Aero-Models site and didn't see it. Is it a more powerful motor than the A50 ? I assumed that just because of the higher number. I have to learn about motors and batteries so please enlighten me. I'm a firm believer in having some horse power in the bank, you can always throttle down, but you can't throttle up once you have the pedal to the metal. I fly at the same field as one of the top pilots (I don't want to drop his name), but he flies his sequence then immediatly lands. I suppose when I get there I'll probably do the same. Well, now that I think about it, landing is part of the sequence, DUH, my flights will be in the 7 minute range, plus or minus, I'm guessing. As far as batteries and chargers go, I've been buying from A123 Racing here in Santa Ana, California, he always knows what I need. But, I'm certainly open to new ideas. Being new to electrics, when you recommend or even mention your favorites, if you could give me a website that would be very helpful. |
Hi Randy,
I just got back from travel and now have a keyboard so I can respond easier than on my iPhone, ha ha. You must have me confused with someone else.... I'm afraid that if you drop my name you'll just get an empty echo and blank stares. LOL. I'm not a top pilot, that's for sure. Anyway, glad to see you are looking at the Wind 110 that we discussed a couple weeks ago. I think it is a good choice. There's a thread on this forum somewhere with lots of info about it. Like I mentioned before, it is best to find a setup that works and copy it. It seems that the A50 is a good starting point. I'm surprised that the recommendation was for a Phoenix Ice 100. I think most guys are running the Ice 80 or HV 85 on the 10s aircraft. I'll look around and see what ESC the guys are tending to use on the A50 setups. Nothing wrong with the Ice as far as I can tell. It just seems that you could get by cheaper with a smaller controller. As for chargers, you see a lot of the FMA Cellpro 10s units out there these days. Lots of Thunderpower 1010's with the external balancer module as well. I have one of each of these and they both work great. I like the Cellpro because it gives a bit more info. If you are going to be playing with electrics then get a good charger like one of these. I have a stack of older smaller units that are collecting dust now. I should have just gotten the bigger charger from the get go. People seem to be having good luck with the Rhino packs from Hobby City. Likewise with the flightmax and other packs. They are going for a good price. I am trying a set of the Turnigy nanotechs which are also reasonably priced. You'll need to get adapter cables for connecting the balancing plug on your lipos to the charger. I got a set for the Turnigy battery to Thunderpower charger here (and they have ones for the Cellpro too): http://www.rcaccessory.com/lipobalan...nadapters.aspx Anyway, bring your 40% extra out and we'll start flying the AMA sportsman pattern. You can practice that while you get your e-plane going. I'll be out there Friday I think. Send me a pm with your email address and I'll let you know when I'm going for sure. Steve. |
ORIGINAL: rcpattern Another option if you want to go cheaper and want to get started is the Wind S 50e. I have one and I really flies nice. Not a lot smaller than the 110, but flies very nice as well. The Wind 110 is its own design, it is not a scaled down Wind S pro, whereas the 50e is a scaled down Wind S Pro and flies very nice. You can run the smaller and cheaper setup with the A50, 16S, and a 6S setup and it is a rocket ship if you want it to be. I have one and on a calm day it flies very similar to my 2m version. The Wind 110 is very nice also, but just more expensive. It is a little larger and heavier, so it does handle winds a little better. I don't think you can go wrong with either setup. Arch Randy |
Thanks Steve,
Dang, I bought a cellpro 4 a couple years ago. Close but no cigar. I downloaded the sequence and the written description and have been studying it. I have to say there are more difficult manuvers in IMAC sportsman, but then maybe I should be comparing the IMAC Basic to the Pattern Sportsman. Anyway, Friday sounds good, if the weather permits. I'll pm you my e-mail address. Randy |
ORIGINAL: Mike Wiz Parallel... serial... What's the differnce? Just kidding. [img][/img] Good catch. That could have caused him a real problem. ORIGINAL: 1bwana1 Just to be sure we are giving good information, you will be using 2 X 4S wired is series for an 8S pack, not parallel. |
Yep. Pattern Sportsman class is the entry level just like Basic is in IMAC. The Wind S 50e wasn't available when I bought my Wind 110. If it had been I might have gone that route.
Having flown both the 110 and the 50, the 110 isnt that much larger in the air. The 50 is every bit as tall as the 110. For visibility I would definitely consider the yellow scheme though. The Red/White/Blue is tough to see on a clear sky as the blue blends right in and there isn't much red for contrast. The bottom shows up great, but the top can be tough to see.
Arch |
The 50 looks pretty cool. Pretty close in size to the 110 but you get to run the single 6s pack. That would be cheaper for sure. I would definitely consider that one. I like the yellow scheme. For our skies, yellow is really a good base color.
If you started in sportsman (like IMAC Basic) you would have more than enough airplane with the 50 or 110. |
I know Chris at F3A unlimited has them both in stock and I believe he has a "combo" deal available. With blue skies I would definitely look at the yellow one.
Arch |
But if you can't see it, the Judge can't either... what they can't see they can't downgrade :)
Have you ever totally lost a plane in the sky before? I have but I'm not having any trouble like that with the 110. I do think the yellow would be easier to see but personally I don't like it as much as the red Wind 110.
I have never totally lost it. There are skies that the orientation can be very hard to determine. Wings level and such. I'm not saying its ugly, or doesn't work. I even picked up a 2nd blue one, but it is not the easiest scheme in the sky to see. Several people have said the same thing watching it fly. After a while you learn to adapt and look at different things, as I am now comfortable with it, but it doesnt mean its any easier to tell orientation.
Arch |
ORIGINAL: rcpattern I know Chris at F3A unlimited has them both in stock and I believe he has a ''combo'' deal available. With blue skies I would definitely look at the yellow one. Arch |
Well, I just pulled the trigger, I called Chris at F3AUnlimited and ordered the yellow 50 with the 16s motor and the ICE 75 controller ? (not the lite), I hope I'm saying all that stuff correctly. He said the controller can be used with an 8s pack if I later go to the 110 size.
Assembling the plane won't be a problem, but when I get to installing the electronics I hope you guys will be here to help. Thanks, and Happy Holidays to all. Randy |
No problem, we'll get you going.
Randy,
That is the exact setup that I'm running in mine. If you have any questions or want pictures of locations of stuff, just let me know. The 16X12 on a 6S 4000mah pack is my favorite setup so far. I can comfortably get 7-8 minutes out of it. Arch |
ORIGINAL: rcpattern Randy, That is the exact setup that I'm running in mine. If you have any questions or want pictures of locations of stuff, just let me know. The 16X12 on a 6S 4000mah pack is my favorite setup so far. I can comfortably get 7-8 minutes out of it. Arch Chris, tell him you sent me there, I'll vouch for you. LOL Yes, pictures would be great. |
Nah, no kickback from Chris...he just lets me play with his cool toys when he finishes them. It is nice to have local. Actually I was going to get the Miss Wind 50, but the wife said, no, she liked the monoplane better since it matched the other 2...so now I have the 3 Wind S planes. I'll get the bipe next though. I'll get some pics tomorrow evening.
You can easily get through the sportsman sequence. I've flown the masters sequence which is close to 7 minutes takeoff to landing, and uses a LOT more power and still had plenty. Arch |
I think you'll be pretty happy with purchase, Randy. These planes from Sebart really fill that space between sport models that look like pattern planes and the high end 2 meter stuff. Good luck and keep us posted!
Hi guys,
Here's my next question, I've been looking at batteries and I will be using the 6cell packs ? and I see another number i.e. 20c, 25c, 30c, 40c.....which one of those do I use ? Thanks Randy |
The C rating is essentially the maximum discharge rate. 20C is 20 times the capacity of the battery and is more than enough for pattern flying. The others are heavier and give you more burst, but isn't really necessary for pattern flying.
Arch |
Thanks Arch,
Excellent, so 20c's it is. |
Looking at Flightmax batteries, the difference between the 4000 and 5000 is just one dollar and the weight difference is 169 grams (5000=844g, 4000=675g). Is 169 grams a lot ?
169 grams is almost 6oz, so it is nearly a half pound heavier. The plane will certainly handle it, but it will fly heavier.
Arch |
I'm thinking that heavier would be good in windy conditions. Maybe it would be good to have some of both.
Am I correct that I read I use just one battery pack per flight ? |
Yes, you would just use 1 per flight. I never liked the idea of adding weight or changing how the plane feels just because it is windier. I think you are better off setting your plane up to fly how you like it and then learning it inside and out as opposed to changing thing between flights. To each their own though. Mine flies fine on smaller packs in the wind.
You might be able to use the 15C 5000ma Flightmax batteries. You just have to be careful how hard you push them. I know some guys are using them in the 10S configuration on 2M ships.
My vote goes to Rhino 3700mAh 25C 600g. I had them on Angel with A5016S and 16x10 prop. Flying time 7-8 minutes without any problem. Rhinos have proved them self over and over again.</p> http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=9341</p> Velco</p> |
I use the Zippy Flightmax 6S 4000 20C pack in my Great Planes Reactor. I have just one pair of them but they have been fantastic! I probably fly about 8 minutes of pattern type aerobatics with a little 3D thrown in here and there. I'll usually end the flight with 3 or 4 touch-n-goes. The plane only weighs about 6 lbs though. I'm not sure what the projected weight of Wind 50 is.
ORIGINAL: Mike Wiz I use the Zippy Flightmax 6S 4000 20C pack in my Great Planes Reactor. I have just one pair of them but they have been fantastic! I probably fly about 8 minutes of pattern type aerobatics with a little 3D thrown in here and there. I'll usually end the flight with 3 or 4 touch-n-goes. The plane only weighs about 6 lbs though. I'm not sure what the projected weight of Wind 50 is. Now on to reciever battery, I noticed in Steve's plane he has a flat lithium type battery (maybe 2.5 inches square) and I searched and see they are 7.4 volts, so I'll need a regulator to take that down to a voltage I can safely plug into my reciever ? and that will operate the servos ? Steve, my theory is to get all these beginner questions answered here then I won't be such a pain in the butt at the field. Weight of the Wind 50 is about 80 oz. if there are still 16 oz. in a pound then it will weigh about 5 lbs. so that sounds good. |
ORIGINAL: desertrider49 ORIGINAL: Mike Wiz I use the Zippy Flightmax 6S 4000 20C pack in my Great Planes Reactor. I have just one pair of them but they have been fantastic! I probably fly about 8 minutes of pattern type aerobatics with a little 3D thrown in here and there. I'll usually end the flight with 3 or 4 touch-n-goes. The plane only weighs about 6 lbs though. I'm not sure what the projected weight of Wind 50 is. Now on to reciever battery, I noticed in Steve's plane he has a flat lithium type battery (maybe 2.5 inches square) and I searched and see they are 7.4 volts, so I'll need a regulator to take that down to a voltage I can safely plug into my reciever ? and that will operate the servos ? Steve, my theory is to get all these beginner questions answered here then I won't be such a pain in the butt at the field. Weight of the Wind 50 is about 80-88 oz. if there are still 16 oz. in a pound then it will weigh about 5-6 lbs. so that sounds good. |
Nope. When flying electric planes there is only 14 oz in a pound. ;)
For planes this size I usually run a BEC instead of an RX battery. In fact, I ran a BEC in my Wind 110 last year too. You just wire them into the power leads that come into the ESC from the battery. Basically, they are a switching voltage regulator that draws power from your main motor battery to power the radio. Among other things, it saves some weight. The other nice thing is that you don't have to bother seperately charging an RX battery. For 6S packs, look at the CC BEC that Castle Creations sells. It's designed to work with your controller. You'll get lots of opinions about why you shouldn't use a BEC but I've been using them for years on planes this size and larger and I've never had a problem with it. ORIGINAL: desertrider49 I'm pretty sure those are the batteries I'm going to order. Now on to reciever battery, I noticed in Steve's plane he has a flat lithium type battery (maybe 2.5 inches square) and I searched and see they are 7.4 volts, so I'll need a regulator to take that down to a voltage I can safely plug into my reciever ? and that will operate the servos ? Steve, my theory is to get all these beginner questions answered here then I won't be such a pain in the butt at the field. Weight of the Wind 50 is about 80 oz. if there are still 16 oz. in a pound then it will weigh about 5 lbs. so that sounds good. |
Randy,
Yes, you will need a receiver battery. You can use a 2 cell lipo and a regulator to bring the voltage down to 6v. You can probably fly all day on a 700mah or so receiver pack. I use a 910 which I only drain 50% on a full day or a smaller 480 if I want to be lighter. The weight difference is minimal so getting some extra capacity for safety margin is a good thing. For the regulator, there are a bunch out there. I have used both Smartfly and Jaccio. I like the Jaccio from Central Hobbies because it has the smart switch feature. both regulators work fine. |
| All times are GMT -8. The time now is 07:00 PM. |
