RCU Forums
-   Electric Pattern Aircraft (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/)
-   -   Builtup stabs for Integral (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/10888993-builtup-stabs-integral.html)
gerrie 01-03-2012 12:29 AM
Hi Guys
A couple of months ago some offered to cut balsa stabs that could be build up for the Integral . Simular to what AJ did for his spark.
Considering this for my Old Integral - Anhedral stabs and Spark wings .
Anyone that can send me in the right direction would be much appreciated
thx
gerrie
Jason Arnold 01-03-2012 01:07 AM
RE: Builtup stabs for Integral
Hi Gerrie,
Dave Snow is the man to speak to. http://www.rcuniverse.com/forum/fb.asp?m=9451223
cheers,
Jason.
Dsnow 01-03-2012 05:58 AM
Hi Gerrie, I also did a build thread http://www.rcuniverse.com/forum/m_10841584/tm.htm that shows how I've been building both a stab and a wing kit. The stab kit can be built with anhedral or flat, I have several wing kits: Spark Dynamic AJ, Spark Evo AJ, PassPort/Visa, Onas and the wing on the build thread that has not flown yet. You can email mail me at [email protected] and I will try and answer any questions you may have.
Do you think there is an interest in a Integral replacement wing kit? Are people still buying this model? I could do the Integral wing or the Xigris if there is interest in wing kits, let me know.
Dave Snow
AC Glenn 01-03-2012 10:55 AM
Dave I didnt know you have a wing and stab kit for the Visa. What all did you change?
Dsnow 01-03-2012 11:50 AM
Hi AC, the wing kit is almost an identical copy to an original Passport wing but with increased dihedral and no wing tips, your existing ones should fit. I only have one stab kit and it's based off the Spark Dynamic, the stab will not save too much weight from the orginal. If you're looking to save some weight the wing kit would be the way to go if your panels are over about 16 oz each ready to fly, new ones with good wood should weigh around 13 oz each ready to fly. The kits are relatively easy to assemble.
Dave
AC Glenn 01-03-2012 12:04 PM
I more worried about the flight characteristics of the wings. If I could really improve the snapping with the builtup wings I would probably stick with the airplane.
gerrie 01-07-2012 01:16 AM
Thanks Dave for your great support this far.
Gerrie
