Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
 Building a built-up pattern stab and wing >
Old 12-03-2011 | 01:01 PM
Default Building a built-up pattern stab and wing
I'm currently building a stab and wing for Mike Mueller and thought I could photo document the build process here. Mike has a Mystic fuse from Todd Schmidt and we are going to put a Spark anhedral stab and a new - never flown - elliptical wing on the plane, kit bashing at it's best. I'm not really good at taking pictures when a build is in progress, really slows everything down, but will try to do my best here. If anyone has any questions or wants to see something specific to the build please let me know and I will attempt to provide a response.
I started with the stab last night for a couple of hours and did the same earlier today. Below are the plans for the stab and some pictures.
Dave Snow
Added 12-7-2011
stab sheeting: 3/32" not the 1/16" as noted in the stab plan
4"x36" long sheeting weights = 14 to 16 grams each for best results
ID:	1694804   Click image for larger version
ID:	1694805   Click image for larger version
ID:	1694806   Click image for larger version
ID:	1694807   Click image for larger version
ID:	1694808   Click image for larger version
ID:	1694809   Click image for larger version
ID:	1694810   Click image for larger version
ID:	1694812   Click image for larger version
ID:	1694813   Click image for larger version
File Type: pdf
Old 12-03-2011 | 01:02 PM
Default RE: Building a built-up pattern stab and wing
Some more pictures.
ID:	1694815   Click image for larger version
ID:	1694816   Click image for larger version
ID:	1694817   Click image for larger version
ID:	1694818   Click image for larger version
ID:	1694819   Click image for larger version
ID:	1694820   Click image for larger version
ID:	1694821   Click image for larger version
Old 12-03-2011 | 03:16 PM
My Feedback: (41)
Looking good Dave. I will carry the thread on when I get the stuff and start attaching it. Thanks, Mike
Old 12-03-2011 | 04:41 PM
Mike gave me the wood and some other goodies today so I could get started on the skins and socket installation for the stab. All the wood was weighed and then divided into three groups: one for each wing panel and one for the stab panels. The three sheets for the stab panels had the edges straightened, sanded and then glued together. I then made some paper sockets for the stab tube and glued them into each panel, these will set for several hours for the Poly-U glue to set.
Dave Snow
ID:	1694891   Click image for larger version
ID:	1694892   Click image for larger version
ID:	1694893   Click image for larger version
ID:	1694894   Click image for larger version
ID:	1694895   Click image for larger version
ID:	1694896   Click image for larger version
ID:	1694897   Click image for larger version
ID:	1694899   Click image for larger version
ID:	1694900   Click image for larger version
ID:	1694901   Click image for larger version
Old 12-03-2011 | 04:44 PM
More
ID:	1694903   Click image for larger version
ID:	1694904   Click image for larger version
ID:	1694905   Click image for larger version
ID:	1694906   Click image for larger version
ID:	1694907   Click image for larger version
ID:	1694908   Click image for larger version
ID:	1694909   Click image for larger version
ID:	1694911   Click image for larger version
ID:	1694912   Click image for larger version
Old 12-04-2011 | 01:07 AM
My Feedback: (15)
Thanks for the build up, and pictures. Following along.
Vince
Old 12-04-2011 | 06:31 AM
My Feedback: (21)
Excellent; subscribed!
mk
Old 12-04-2011 | 01:25 PM
Some pictures of finishing the stab skins, cleaning up the socket installation and gluing the bottom skin to one panel. When sheeting with the jigs it's best to use a piece of poster board between the skin and jig, this will help reduce any denting of the skin during the pressing of the skin/frame assembly. Also use a sheet of plastic between the jig and frame otherwise the two could be glued together. After about 4 hours for the glue to set the second panel will be pressed using the same jigs.
Dave Snow
ID:	1695226   Click image for larger version
ID:	1695227   Click image for larger version
ID:	1695228   Click image for larger version
ID:	1695229   Click image for larger version
ID:	1695230   Click image for larger version
ID:	1695231   Click image for larger version
ID:	1695232   Click image for larger version
ID:	1695234   Click image for larger version
ID:	1695235   Click image for larger version
ID:	1695236   Click image for larger version
Old 12-04-2011 | 01:27 PM
More
ID:	1695238   Click image for larger version
ID:	1695239   Click image for larger version
ID:	1695240   Click image for larger version
ID:	1695241   Click image for larger version
ID:	1695242   Click image for larger version
ID:	1695243   Click image for larger version
ID:	1695244   Click image for larger version
ID:	1695246   Click image for larger version
Old 12-04-2011 | 01:36 PM
Jason Arnold's Avatar
Hi Dave,
Why do you use paper for the socket and not the glass socket that comes with the stab tube?
Regards,
Jason.
Old 12-04-2011 | 02:16 PM
Hi Jason, at first the stabs were replacements for existing stabs so the socket needed to match the exact tube size of the plane and this was the best way that I could see doing it. You can build the panels either way but I still like the paper because it gives a better fit to the tube, no slop. I've also done/do paper sockets for the wing panels and that's more due to availability of the sockets but it does save some weight. Mike gave me the socket with the wing tube so I do not need to make one.
Dave
Old 12-04-2011 | 02:56 PM
Thanks Dave,
Had to be a good reason for it...
Cheers,
Jason.
Old 12-04-2011 | 03:49 PM
underdw's Avatar
Looking forward to seeing the elliptical wing. Balsa really has amazing ability to form around compound curves.
I remember my father building a 70s vintage pattern plane dressed as a Spitfire. I was too young to appreciate how he cut the foam cores or skinned the elliptical wings, but it must have been with some neat tricks.
Dan
Old 12-04-2011 | 06:16 PM
Hi Dan, I think the wood built-up wings have more possibilities in wing type design than foam; your dad must have been very talented to make a foam elliptical wing. I've already built my elliptical wing panels and the hardest part was rounding the leading edge, the jigs make alignment and sheeting relatively easy.
After about 5 hours the stab panel was pulled and the other panel is in the press now. Here are several pictures; the Poly-U glue has expanded around the spars and ribs, a hole near the tip is cut through the skin to locate the waste portion when the elevator is cut off - a leading edge will be attached to the elevator portion just like in a foam wing.
Dave
ID:	1695399   Click image for larger version
ID:	1695400   Click image for larger version
ID:	1695401   Click image for larger version
Old 12-05-2011 | 07:58 AM
Nice work Dave. Looking forward to the progress..
Todd
Old 12-05-2011 | 10:15 AM
Dave I'm just finishing the stabs I got from you and can say that they are very light and were actually fun to build. The original panels were 5.35 and 5.1 oz each and the new panels are tracking to be close to 3.5oz finished with the servo.
I would like to consider replacing the Integral wings but am not convinced that I should completly change to the Spark wing due to the additional effort to retune the plane.
These kist are very well thought out and not too difficult to build. It would great if you considered direct replacements panels....I would sign up for a set of Integral wings for sure!!
Colin.
Old 12-05-2011 | 12:10 PM
Thanks Todd, I saw the fuse you did for Mike and it looked beautiful, this should be an interesting plane once finished.
Hi Colin, Mark Atwood really pushed me hard to get the wings and then stabs to build easier than the first version without the jigs and no interlocking spars/ribs, these are much easier to build. I am glad you had a good experience building the stabs and that’s a big weight savings especially at the back of the plane. You may need to move the motor battery back some, this should help make the plane fly even better by concentrating the weight near the cg of the plane. I do have a PassPort/Visa wing that is similar to the Integral but will think about doing a copy of the Integral, actually I like the Xigris wing better than the Integral - it's thinner and should snap better than the thicker Integral wing.
Here are both panels with the bottom skin glued on, the mounting for the elevator servos, adding doublers for the hinge and then placing glue on the ribs/spars to sheet the top of the panel. I will let the panel set in the jig for a minimum of 6 hours then lay up the second panel in the jigs.
Dave
ID:	1695703   Click image for larger version
ID:	1695704   Click image for larger version
ID:	1695705   Click image for larger version
ID:	1695706   Click image for larger version
ID:	1695707   Click image for larger version
ID:	1695708   Click image for larger version
ID:	1695709   Click image for larger version
ID:	1695711   Click image for larger version
ID:	1695712   Click image for larger version
ID:	1695713   Click image for larger version
Old 12-05-2011 | 01:23 PM
Dave, the Int wing snaps pretty well despite being ridiculously heavy....I can't tell that the Xigris airfoil is significanly better. I'm pretty sure that a light Int wing will be every bit as good as the Xigris. In fact I'm starting to think that the thicker wing is what we want for P13. I find the heavy Int easier to manage speed during P13 than the signifcantly lighter Xigris....I believe the wing is the main reason as I can't really find other sources of drag between these two designs.
A direct/reverse Engineered Int wing will allow 'drop in' to old Int with few to no changes.
If there is anything I can do to help encourage you in that direction just let me know.
Colin.
Old 12-05-2011 | 08:55 PM
The humidity in the house must be a little higher than normal because the Poly-U glue was set in about 5 hours and I was able to get both top skins glued on today. After removing from the jigs the leading edges and tips were sanded, panels sized to each other and the 1/4" leading glued and taped on.
Dave
ID:	1695935   Click image for larger version
ID:	1695936   Click image for larger version
ID:	1695937   Click image for larger version
ID:	1695938   Click image for larger version
ID:	1695939   Click image for larger version
ID:	1695940   Click image for larger version
ID:	1695941   Click image for larger version
ID:	1695943   Click image for larger version
ID:	1695944   Click image for larger version
ID:	1695945   Click image for larger version
Old 12-05-2011 | 08:57 PM
More
ID:	1695947   Click image for larger version
ID:	1695948   Click image for larger version
ID:	1695949   Click image for larger version
ID:	1695950   Click image for larger version
ID:	1695951   Click image for larger version
ID:	1695952   Click image for larger version
ID:	1695953   Click image for larger version
Old 12-06-2011 | 02:00 AM
guille2006's Avatar
Suscribed... looks good!!
Old 12-06-2011 | 06:17 PM
Today the leading edges was sanded, tips glued on, tips sanded, leading edges and tips rounded, elevators cut from panel, trailing edge of panel / leading face of elevator sanded and leading edge of elevator glued on.
Dave
ID:	1696371   Click image for larger version
ID:	1696372   Click image for larger version
ID:	1696373   Click image for larger version
ID:	1696374   Click image for larger version
ID:	1696375   Click image for larger version
ID:	1696376   Click image for larger version
ID:	1696377   Click image for larger version
ID:	1696379   Click image for larger version
ID:	1696380   Click image for larger version
ID:	1696381   Click image for larger version
Old 12-06-2011 | 06:20 PM
More
ID:	1696383   Click image for larger version
ID:	1696384   Click image for larger version
ID:	1696385   Click image for larger version
ID:	1696386   Click image for larger version
ID:	1696387   Click image for larger version
ID:	1696388   Click image for larger version
ID:	1696389   Click image for larger version
ID:	1696391   Click image for larger version
ID:	1696392   Click image for larger version
ID:	1696393   Click image for larger version
Old 12-06-2011 | 06:21 PM
More
ID:	1696395   Click image for larger version
ID:	1696396   Click image for larger version
ID:	1696397   Click image for larger version
ID:	1696398   Click image for larger version
ID:	1696399   Click image for larger version
ID:	1696400   Click image for larger version
ID:	1696401   Click image for larger version
ID:	1696403   Click image for larger version
ID:	1696404   Click image for larger version
ID:	1696405   Click image for larger version
Old 12-07-2011 | 06:00 PM
Shaping leading edge of elevators, hinging elevators, installing hard points with pilot hole, installing adjusters onto root ribs, final panel weights. These were built with average to heavy wood (19/20 gram per sheet) that Mike supplied, I anticipate a finished ready to fly weight (minus elevator servo) of 3.5 oz or less and this is very similar to other stabs that I've built and tell builders to expect.
Stab build finished, the wing will start shortly.
Dave
ID:	1696812   Click image for larger version
ID:	1696813   Click image for larger version
ID:	1696814   Click image for larger version
ID:	1696815   Click image for larger version
ID:	1696816   Click image for larger version
ID:	1696817   Click image for larger version
ID:	1696818   Click image for larger version
ID:	1696820   Click image for larger version
ID:	1696821   Click image for larger version
ID:	1696822   Click image for larger version
