Idle up
Does anyone use an idle up function on their eletric setup, or just land with the prop not turning
RE: Idle up
Um, both. I use the Idle up while I'm flying. I have it set to the "idle" speed that I want to maintain for stall turns, spins, etc. I flip the idle up off for landing (so i'm 'dead stick') as well as on long downlines when I want the braking engaged.
RE: Idle up
Hi Mark,
Am Icorrect inpresuming that you cannot have an idle and braking. It is an either or situation? Regards Peter |
RE: Idle up
Yes, that's correct. The speed controllers don't apply braking until the throttle is all the way down.
RE: Idle up
Thanks Mark. I rather suspected that but it is good to know for sure!
RE: Idle up
I set mine up on a kill switch through the radio. I use Futaba, and have digital trims for throttle unlike JR. So all i do on final is hit the throttle kill, and the motor dies. When starting the motor, i initiate the kill switch, then hook up the batteries, my esc beeps a few times, then bump the throttle up and voila, she is ready to go.
RE: Idle up
I use brake, but idle up in a condition only for spin entry.
Regards |
| All times are GMT -8. The time now is 05:03 AM. |
