RCU Forums
-   Electric Pattern Aircraft (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/)
-   -   CA Model Andes biplane (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/11655734-ca-model-andes-biplane.html)
swk550 10-23-2018 07:38 AM
https://cimg6.ibsrv.net/gimg/www.rcu...088fa776c3.jpg
https://cimg0.ibsrv.net/gimg/www.rcu...a3a1fdd300.jpg
https://cimg7.ibsrv.net/gimg/www.rcu...f6a715bce1.jpg
https://cimg2.ibsrv.net/gimg/www.rcu...7808fd8c3a.jpg
https://cimg6.ibsrv.net/gimg/www.rcu...719f3c1410.jpg
https://cimg8.ibsrv.net/gimg/www.rcu...54392cfe4d.jpg
https://cimg0.ibsrv.net/gimg/www.rcu...2fe9d9bf0f.jpg
https://cimg3.ibsrv.net/gimg/www.rcu...e2638daad9.jpg
https://cimg4.ibsrv.net/gimg/www.rcu...8ac331665e.jpg
I just received my yellow base color Andes biplane that I ordered from F3A Unlimited. Mike Mueller took care of all the ordering details from CA Model Argentina. This is a yellow base color and it only took five weeks to arrive. So far the quality is very good and the fuse paint job is nice. I'm not sure who supplies the metallic blue covering. I'd like to order a roll as a back-up. These are the component weights:
accessory pack: 378g
Fuselage: 966g
Canopy: 160g
Rudder: 58g
Right stab: 82g
Left stab: 78g
Top wing: 470g
Bottom wing: 528g
Spinner: 30g
Wheel pants: 50g
Wheels: 20g
Front Plettenberg plywood nose mount: 10g
Landing gear: 120g
rgreen24 10-24-2018 05:05 AM
What do you think your finished weight is going to be?
swk550 10-24-2018 05:39 AM
By my build weight spread sheet, it should come out around 5.0kg to 5.040kg. I can possibly shave off some more weight, but I am using build components I have on hand.
swk550 10-24-2018 11:31 AM
Andes motor options
https://cimg7.ibsrv.net/gimg/www.rcu...3fb3f23079.jpg
https://cimg8.ibsrv.net/gimg/www.rcu...fb732d7949.jpg
https://cimg0.ibsrv.net/gimg/www.rcu...f8c2c6211f.jpg
Attached are photos of my three motor options with mounting hardware weights included. I plan on using the Hacker C54 Acro motor. The estimated final build weight should be approx. 4950g. Now just need to determine recommended right and down thrusts.
rgreen24 10-24-2018 11:58 AM
From my understanding of people who have owned this model; follow the nose attach your motor and go, seems like the thrust that's built in, is right on.
can you show pics of your hardware?
swk550 10-25-2018 04:34 AM
Andes incidences and set-up information
Here is the set-up information provided by Marcelo at CA Model:
Hi Steve
Here the setup Mariano and me use on Andes.
Motor down thrust -1.5
Top wing +0.5
Bottom wing 0
Stab 0
Cg 145-150mm from leading Edge
Any other info please let me know
.Best regards
Marcelo
swk550 10-26-2018 05:29 AM
Andes carbon fiber reinforcements
https://cimg0.ibsrv.net/gimg/www.rcu...e194cacc23.jpg
https://cimg3.ibsrv.net/gimg/www.rcu...c7018ff9f3.jpg
https://cimg8.ibsrv.net/gimg/www.rcu...2d186d1dfd.jpg
On all of my pattern planes, I reinforce the motor rear mount brackets and the landing gear mounting plates. Attached are photos of the Andes reinforcements using Dave Brown CF toe.
swk550 10-26-2018 05:35 AM
Andes cooling modifications
https://cimg3.ibsrv.net/gimg/www.rcu...254e6ca8b5.jpg
https://cimg7.ibsrv.net/gimg/www.rcu...4faf787c52.jpg
https://cimg3.ibsrv.net/gimg/www.rcu...c2d1d0acd5.jpg
I like plenty air flow for cooling. I have enlarged the rear fuse air exits and cut out the fuse wing bulkheads for some additional air flow. When I fly the plane, I'll compare temperatures to my 2m mono planes.
swk550 10-29-2018 06:23 AM
Rudder pull pull cable
https://cimg2.ibsrv.net/gimg/www.rcu...1a837fe926.jpg
https://cimg8.ibsrv.net/gimg/www.rcu...846849c8c4.jpg
swk550 10-29-2018 06:28 AM
Sndes stab RTV seal
https://cimg5.ibsrv.net/gimg/www.rcu...4511f9262a.jpg
I like to seal any small gaps of the stab with the fuse. First I install the stab tube CF rod screws. Then I put a bead of clear RTV along the edges of the stab. Wax paper and masking tape is used and the stab is installed. I use a straight edge to scrap off any excess RTV. I let the RTV cure for eight hours before I remove the masking tape and wax paper.
wattsup 10-29-2018 09:51 AM
Well Steve, I see from the Budd soft mount you are going with the Hacker C54. That 2 ozs does make a difference overall! Want to sell me the Pletty Advance? Please contact me if you are interested.
Ricardo M. 11-03-2018 01:26 PM
I am waiting for mine. Very iterested in your built thread. Also thinking in motor choice.
swk550 11-03-2018 02:01 PM
ESC weights
https://cimg9.ibsrv.net/gimg/www.rcu...3855b51148.jpg
https://cimg7.ibsrv.net/gimg/www.rcu...45d409a2e2.jpg
https://cimg1.ibsrv.net/gimg/www.rcu...b514dea14a.jpg
I weighed my ESC's
OS 1100 - 132g
Hacker Spin 99 - 122.4g
Jeti Mezon 95 Opto - 132g
Jeti Mezon 115 Opto - 152.2g
I am going to use my OS 1100 ESC
swk550 11-03-2018 02:05 PM
Prop and spinner for the Hacker C54 Acro
https://cimg7.ibsrv.net/gimg/www.rcu...0428dcbe90.jpg
https://cimg4.ibsrv.net/gimg/www.rcu...9dd9c1211e.jpg
I am installing a 83mm Falcon spinner and Falcon 20.5 x 14.5 CF prop
swk550 11-03-2018 02:15 PM
Falcon Allure CF landing gear
https://cimg5.ibsrv.net/gimg/www.rcu...f0dd47fbf1.jpg
https://cimg8.ibsrv.net/gimg/www.rcu...c8776300f8.jpg
https://cimg8.ibsrv.net/gimg/www.rcu...e4e15a12e8.jpg
https://cimg2.ibsrv.net/gimg/www.rcu...9204f7d0e0.jpg
I am installing the Falcon long Allure CF gear. It only weighs 106g. I am also installing CK Aero Allure wheel pants and MPI thin wheets. This set with axels only weighs 58.5g. I ended up installing blind nuts in the landing gear plywood mounts. I had to cut access holes in the bottom of the fuse for the soc hd cap screws.
ltc 11-03-2018 02:24 PM
Apart from weight, is there any other reason why you chose the Falcon Alure legs?
Are they ‘taller’?
Any mods to the LG plate necessary for them to fit?
swk550 11-03-2018 02:59 PM
https://cimg2.ibsrv.net/gimg/www.rcu...840cbf6c15.jpg
https://cimg4.ibsrv.net/gimg/www.rcu...bde49f7b98.jpg
I chose the Falcon gear because they were lighter. Falcon also makes a shorter gear that fits as well. It's the number 102 gear. The two holes on each fuse side are too wide for either the CA landing gear or the Falcon gear. I simply just drilled holes that were less far apart. I used the factory ply battery tray. It was fairly light. I did paint it black simply for looks.
swk550 11-04-2018 07:16 AM
Andes wing weights with servos
https://cimg2.ibsrv.net/gimg/www.rcu...4e99420323.jpg
https://cimg4.ibsrv.net/gimg/www.rcu...0e8b109e88.jpg
https://cimg8.ibsrv.net/gimg/www.rcu...d66b3f0715.jpg
Here are the wing weights with servos and linkages
swk550 11-04-2018 07:26 AM
Other build pictures
https://cimg5.ibsrv.net/gimg/www.rcu...41c6773143.jpg
Battery tray installation
https://cimg4.ibsrv.net/gimg/www.rcu...71427f2c6b.jpg
CA Model wheels
https://cimg9.ibsrv.net/gimg/www.rcu...1cd12c05a2.jpg
Andes fuselage paint scheme (very good quality finish)
https://cimg7.ibsrv.net/gimg/www.rcu...ef77fc1c32.jpg
Andes wing and stab colors (yellow factory base)
https://cimg7.ibsrv.net/gimg/www.rcu...9a4102b689.jpg
Andes painted wheel pants
https://cimg5.ibsrv.net/gimg/www.rcu...a37ea64b77.jpg
Arming harness
ltc 11-04-2018 11:15 AM
Very interesting aileron servo linkage
Waa this again for weight?
Would a turnbuckle and ball end be much heavier?
swk550 11-04-2018 12:46 PM
Aileron linkage
Good observation. I used parts I had on hand. I would need 2" turnbuckles and some more 2-56 ball links. It may be slightly heavier but only maybe 5g per servo. I have only located Seacraft 50mm long x 3mm thread aluminum turnbuckles sold by F3A Unlimited. If I need to replace the servos, that what I will use.
I don't have a picture of the finished and assembled airplane. Final Andes weight ended up at 4940g. If our weather clears up and the winds die down, hope to maiden the plane next week.
ltc 11-04-2018 01:01 PM
Best of luck with the maiden
If you could post a pic of the assembled plane, that would be great.
Ricardo M. 11-04-2018 01:09 PM
4940g with which batteries?
swk550 11-04-2018 01:55 PM
GForce 5000mah battery
https://cimg4.ibsrv.net/gimg/www.rcu...c447321723.jpg
[QUOTE=Ricardo M.;12475992]4940g with which batteries?
I’m using GForce 5000mah 30c batteries with a weight of 1123g
drac1 11-04-2018 01:55 PM
I would think a ball link on the servo arm to keep the push rod straight would have been better.
