Jeti Mezon/Himax 6330 Pro ESC settings
It's been a few years since I used this motor and never with this ESC. Hopefully someone here can share their settings. If I recall, this is a 20 pole motor and I think I used to run this at PWM Rate 12kHz. What are all the Mezon brake and ramp related settings you like?
Originally Posted by luckymacy
(Post 12679169)
Timing 24 degrees Pole count 20 PWM 8Hz Breakmanual 40% start power brake delay 0.0 end power 60% brake speed .1 Auto Cut off 3.0v per cell Initial end point Auto High end point 1.9 BEC voltage 8.0 Andrew |
Andrew, I'm curious with the selection of 0.1 brake speed does this mean you don't need any transition time between the 40% start and 60% end brake? Have I understood these settings correctly.
Mark |
The .1 is the time it takes to go from 40% to 60% throttle. I have found that the .1 gives the right speed for the airplane to not build any speed on the downline.
Originally Posted by flyboy91
(Post 12679183)
Here should be some settings to get you close
