RCU Forums
-   Electric Pattern Aircraft (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/)
-   -   oxai beryll (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/4750668-oxai-beryll.html)
underwood1 09-15-2006 05:36 AM
oxai beryll
guys,
what is the best set up for a oxai beryll???,as this the new jedi art,would is the best motor etc.to use .
Neo02 09-15-2006 08:40 AM
RE: oxai beryll
ORIGINAL: underwood1
I think you can't go wrong with the vice-champion Roland Matt's setup: Hacker C50XL, Hacker 90 Opto, Thunder Power 10S4P 5300 mAh. Prop would be 21x13 or 22x12.
Of course, it will work with all the latest setups, as well (NEU motors, Plettenbergs, Axis, ...).
Regards,
-Fabrizio
underwood 09-19-2006 11:12 AM
RE: oxai beryll
thank for the advice,what are the best chargers and balancers to get???,thunder power seams to be the favorite when looking around!!!
regards
underwood
Neo02 09-20-2006 07:51 AM
RE: oxai beryll
ORIGINAL: underwood
That is correct, especially for the TP balancer (10S at once), a perfect match for the TP batteries. On the chargers there aren't any favourites: look around in these forums and pick one that suits you and your wallet (after motor/esc/cells/balancers there won't be much dough left.... :) )
I have an Orbit Microlader and 2x Hyperion LBA10s-networked balancers, very happy with this setup.
Regards,
-Fabrizio
Magne 09-20-2006 12:46 PM
RE: oxai beryll
If you are using the TP batteries and balancers, then I would recommend the TP charger as well.
There is a communications cable connecting the balancer to the charger, and this system will prevent the charger from starting the charge if it is set for the wrong cell count. (Mismatch between the cell number set on the charger, and the number of cells that the balancer detects.) There will also be other safety features, such as stopping the charge if the balancer sees more than 4.24V in any of the cells. This will not work if you use a different charger.
Magne
darkvader 09-20-2006 01:15 PM
RE: oxai beryll
Getting back to the point of that post.
Beryll:C50-14XL or C50-15XL ?
skywalkermh 09-28-2006 02:55 AM
RE: oxai beryll
I would suggest 13XL with Schulze 32.80KA ESC and APC 20x13 or Mezjik 20x12W carb. I used this setup on my Oxai Pinnacle-E. It gives you more clearance for the prop and the new Schulze gave you proportional break on downline.
Matt
