E motor mounting dims
1 Attachment(s)
Hi All,
I was wondering, with all the outrunners around, how close are they to the same distance from back of mount (rear mounting) to back of spinner backplate (1)? And is there a standard bolt pattern for these rear mounts (3)? Pletty Rimfire Axi(s) Hacker Hyperion Eflight Cyclone anymore I'm missing? After I drew the motor, what about the same for the front (2)? |
RE: E motor dims
Jason the AXI/F3A
back of motor to back of spinner backplate is 71 MM spinner back plate to front of motor and this tapers so closest to prop shaft is 9mm and 15 mm is the outside of case. the only demension different on the AXI 5320/28 would be the lenght and it is 61 mm Steve Maxwell |
RE: E motor dims
Jason,
Plett Extra 30 Evo that dim is 67mm Link to installation drawing on Plett website: http://www.plettenberg-motoren.com/U...0evo/Masse.htm Malcolm |
RE: E motor dims
the cyclone f3a
Weight 19.4 oz 550G Diameter 2.6 Inch 65mm Length 3.3 Inch 83mm Shaft 8m marcelo |
RE: E motor dims
The E-flite Power 160 is 72mm from back of mount to the front of the hub and 9mm from front of hub to motor. This is when mounted at the rear with front prop hub per your drawing.
Per the spec: Weight: 650g (23.0oz) Overall Diameter: 63mm (2.50 in) Shaft Diameter: 8mm (.30 in) Overall Length: 64mm (2.50 in) |
RE: E motor dims
Thanks guys for helping with this. I made the drawing a bit easier to understand what I was looking for, I hope. I also added the Cyclone motor
RE: E motor dims
How about 3 for the mounting bolts Jas.
AXI 5330/F3A #1= 71mm #2= 9mm and #3 = 31mm AXI 5320/28 #1= 61mm #2= 9mm and #3 = 31mm |
RE: E motor dims
1) 72mm from back of mount to the front of the hub 2) 9mm from front of hub to motor 3) 52 mm between mounting holes on motor mount |
| All times are GMT -8. The time now is 12:03 AM. |
