To B(ec) or Not to B(ec)
1 Attachment(s)
I've been working on getting back into pattern with an 8s setup in a scratch built plane that I am going to build from scaled down and modified Gator Giles plans. I pretty much know the rational for running a separate rec battery and regulator, especially in full 2m planes flying Masters and FAI. Right now I am pricing components and have to work within a pretty tight budget. I will be flying intermediate with a plane that is about the same size as a Focus Sport, but hopefully a little lighter. My planned setup so far is;
AXI 4130-20 (fixed- I already have one) Rhino 4s3700 x 2 Servos-probably some Hitec 625's I have laying around. ESC- Turnegy 100a BESC, or ??? Would anyone suggest any thing else? Opinions appreciated. Also, when I get the budget for a backup, what do people think of Scorpion Motors. A guy I fly with around here is really sold on them, but he flies mostly 3s and 4s stuff. |
RE: To B(ec) or Not to B(ec)
I LIKE Scorpion. They are in several of my planes. I did have trouble with one, build thousands of anything and a problem will have to crop up sooner or later, but Randy at RCDude.com came through to make things right. Check his offerings out when you get around to shopping for Scorpion.
The Corsair and Addiction here are mine: http://www.rcdude.com/servlet/.fc11d...onSetups5/Page gb |
Not to BEC. If the 8s pack goes you not only lose power; you also lose your plane as you have NO control.
ORIGINAL: randy10926 Not to BEC. If the 8s pack goes you not only lose power; you also lose your plane as you have NO control. |
You can special order the Castle controller without the heatsink which saves a lot of weight.
It runs so cool you really don't need the heatsink. This summer I flew at a contest with Chip Hyde and Todd Blose who were running the Castle HV85 with no heatsink and they had no problems in the south Texas 105 deg summer heat. tommy s |
Just went to CC website, and they appear to have a new product called CC ICE.
http://www.castlecreations.com/produ...oenix_ice.html Their 75 amp model seems adequate, but is a BEC type ESC. They recommend using an add on BEC/regulator if you are planning a high servo load. There goes the cost and weight savings. The specs on the website claim that it can deliver 5 amps out of the BEC at full power on 8cells. Will this be enough? (I've never run any thing bigger than 3cells and have no experience with what servos on this size plane draw) It would be great if I could disable the BEC, and run a 2cell with a Jaccio type reg for the receiver. I sent an e-mail to tech support at Castle about this. I should get a response in a few days. |
ORIGINAL: dreadnaut Their 75 amp model seems adequate, but is a BEC type ESC. They recommend using an add on BEC/regulator if you are planning a high servo load. There goes the cost and weight savings. |
I would recommend staying away from BEC's. It is just to much of a risk. If something burns up in your aircraft you have now just lost the entire airframe. I've had it at times where a battery can come disconnected in flight or ejected then you have just lost your plane. With Lipo's being very inexpensive from China get a cheap 730 2 cell pack and a regulator and you will not have to worry.
Andrew Jesky |
Andy,
Thanks for the reply, I already have a couple of 640 2s Rhinos on order. (should be fine for a .110 sized setup) Have not yet ordered a regulator. Is the Jaccio still available? |
Jaccio's are still sold at Central.
[link]http://www.centralhobbies.com/Electrical/voltage_regulator/Perfectstch.html[/link] Chris |
Also consider Ed Alt's regulators from Tech-Aero Designs. Ed really goes the extra mile with the features found in his regulators.
Thanks all for the opinions and advice. I will defiantly be running a separate Rec. battery. The workshop is almost ready and I will be ordering wood in a week or two. There may be a build tread coming, if it looks like I will have time to get this done quickly.
EDIT: Would anyone recommend a regulator with a "safe switch"? |
Hi, I would recommend the Radio South regulator with fail safe switch. That is what I am running now. Reeves in Alaska.
Last weekend, I saw with open eyes the differences that Tech-Aero Regulators from Ed Alt have going for them. I removed the heat shrink from a R.S. and a Jaccio regulators that I had laying around and compared it to his . They(R.S. and Jaccio )have worked and have been around for years, but Ed's have significant and additional design features. I'd suggest you contact him to get the low down.
| All times are GMT -8. The time now is 12:17 AM. |
