RCU Forums
-   Electric Pattern Aircraft (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/)
-   -   Fast charging (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/9064402-fast-charging.html)
ytell 09-02-2009 11:36 AM
Fast charging
What is the prevailing conception regarding Lipo fast charging? ( 2C, 3C rates)
Assuming a smart charger like the Cellpro 10s is used, does it affect pack longevity?
Do you guys fast charging your packs on a regular basis? Only in the field? Never?
Yoav
f3a05 09-02-2009 11:51 AM
RE: Fast charging
I don't know about other places, but here (in the UK), it's largely academic about being able to charge at more than 1C, for the typical 5000-odd mAH 10s f3a pack-the limiting factor is not so much the charger,but the regulated power supply-using the Cellpro charger at 1C, the power supply(rated at 20 amps) is usually running at around 20-21 amps for most of the charge.....
tommy s 09-02-2009 03:10 PM
RE: Fast charging
I never fast charge my Lipo batteries. They do not self discharge so I can charge
all my packs on Friday night before a contest or a weekends flying and never have to
charge at the field. It is my understanding no matter how good the charger is, fast
charging does lessen the life of the batteries.
tommy s
woodie 09-02-2009 07:38 PM
RE: Fast charging
I run large battery sets (10s 5000mah) and my charger won't handle over 1C when charging those. I have charged smaller batteries at 2C with no noticeable affect.
The newer batteries like the Hyperions are advertising 5C charging with no impact on longevity. Only time will tell.
Woodie
tIANci 09-02-2009 09:42 PM
RE: Fast charging
Lipos of 20C to 30C discharge rate can handle 2C-2.5C charge rates. BUT they will die faster. That is a fact. Those who use really good chargers can charge at 0.25C to 0.5C and that will truly prolong the life of a battery. This is what one of the leading manufacturers of lipos tells me. See the EP car guys, they fast charge their batts for more punch and the batts do not last.
I would stick with no more than 1C.
mikehannah 09-04-2009 06:00 PM
RE: Fast charging
Hi Woodie
Your statement about Hyperions batteries is not strictly true. What Hyperion claim is that the Gen 3 batteries will hold up several time longer than equivalent cells on a similiar charging regime not no impact on longevity. In short if you hammer them they wont last as long but will last longer than other makes of cell.
I have just bought four sets of packs for my Winds S and I dont intend charging them above 0.8C. ( To prolong my substancial investment)
Other manufacturer have made similiar claims ( eg Flightpower) but so far Hyperion are the only company to have their claims independently verified.
On a side note Hyperion are the only cells I have seen that are delivered in a custom made cardboard box with heavy padding inside. Not the cheap plastic bag most other manufacturers put their product into. Also the standard of construction of the packs is excellent. Much better than some other more expensive cells.
Mike
woodie 09-05-2009 12:18 AM
RE: Fast charging
Mike, thanks for the clarification, you are probably correct.
Woodie
ytell 09-05-2009 04:54 AM
RE: Fast charging
Mike
Is there any known data or documenst to supoort Hyperion verification of the claim that their packs will last longer under similar charging conditions?
Yoav
woodie 09-05-2009 12:42 PM
RE: Fast charging
Yoav,
There is a forum for Batteries and Charger on RC Groups that has a lot of data about batteries. Look for the thread about Hyperion G3 batteries and specifically a user on that thread named 'Everydayflyer'. He does a lot of battery testing and has tested the G3s extensively and under severe conditions. Lots of cycles and fast charged each time. His tests are pretty scientifical, or I should say documented, since he does independent tests for RC Lipo battery makers (assemblers).
Woodie
Silent-AV8R 09-05-2009 05:38 PM
RE: Fast charging
In a practical sense it doesn't matter. I use 5,000 to 5,300 mAh packs. My poor little Hyperion DUO charger can only charge them at 1.6C to 1.7C. In the real world this makes less than 12 minutes difference in a charge cycle for me, so I just use 1C and it is what it is.
ytell 09-06-2009 01:31 PM
RE: Fast charging
Thanks Woodie,
I wasn't aware of this forum and it's really helpful
Yoav
