RCU Forums
-   Electric Pattern Aircraft (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/)
-   -   Post Your Battery Weights (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/9539972-post-your-battery-weights.html)
Jetdesign 02-27-2010 10:58 AM
I think this will be a good resource to have. Please post the actual weight of your batteries so we can have some real numbers to play with.
Zippy Flightmax 5S 30C 5000mah 660g/1.45lb
30A Anderson Powerpole Connectors (advertised 650g)
Turnigy 3S 30C 3600mah 319g/0.70lb
Stock (shielded bullet) connectors (advertised 390g)
Neu Energy 2S 25C 400mah 33g/.07lb
Deans Micro Connector (advertised 10g)
NMP Li-Io 2S 2600mah 97g/0.21lb
Standard Connector
tph1 02-27-2010 03:39 PM
RE: Post Your Battery Weights
my Rhino 6S 3700's weigh 20.88 oz/592g
Velco 02-28-2010 07:59 AM
Joe,</p>
Zippy Flightmax 5S 30C 5000mah are advertized as 650g, 740g is the shipping weight;</p>
Spec.
Capacity: 5000mAh
Voltage: 5S1P / 5 Cell / 18.5v
Discharge: 30C Constant / 40C Burst
Weight: 650g (including wire, plug &amp; shrink wrap)
Dimensions: 145x48x40mm
Balance Plug: JST-XH
Discharge Plug: 4mm Bullet-Connector
</p>
So far I have found the battery weights advertised on HK to be quite accurate for 5-6 different types of battery packs I have (had) so far.</p>
Jetdesign 03-12-2010 08:46 AM
Rhino 5s 4900mah: 645g
underdw 03-13-2010 08:54 PM
TP prolite G4 5s 5000, purchased 1/10 590gm with connector.
Hyperion CX 25c G3 5s 5000, purchased 1/10 630 to 640gm with connector. (advertised as 622gm)
Jetdesign 05-17-2010 07:19 PM
Can't seem to edit the above post, but just got a set of Rhino 20C 4900mah 5S batteries and they are 628g ea.
Rhino 2S 460mah 20C is 30g.
Just saved 3oz in my plane :D
2Sunny 05-17-2010 08:05 PM
1 Attachment(s)
Hey Joe,
Great to see you this Saturday. How was the Fun-Fly? By the way your plane is "kick butt", and I love how well it flew with a 17x12 [X(]
Here are a few picks from a previous post. Just interesting to see what one can do with a little cutting and pasting in terms of shaving grams :)
While I'm at it let me post some battery weights:
1) TP Prolite V2 5300 mAh 1170g
2) True RC 10C/20C 5000 mAh 1174g
3) Power Unlimited 20C 5000 mAh 1183g
4) Zippy Rhino 20C 4900 mAh 1233 g
5) TP ProLite V2 4350 1027g
Hey remember when . . .
Rune 05-18-2010 12:39 PM
anyone have the weigth off Zippy Flightmax 5 s 5000 15 C ...I just got some batteries from Hobbycity and one off them was marked as 15C but its just some few gr.. lighter than the 20 ca 6 gr ...in their website it should be about 50 gr lighter and wonderd that it maybe is marked wrong...they also sold out off the 15 C </p>
snaproll4 05-18-2010 07:17 PM
I have three sets of Zippy 15C/5000. One set weighs 1155 grams and the other two weigh 1165 grams including deans.
Only ten cycles on these sets, but they are great so far.
Steve
Rune 05-19-2010 04:26 AM
the 1 5s 15c that I got weighs 620 gr so I think it maybe are wrong ...maybe is a 20c
iflyrctoo 05-22-2010 11:44 PM
I tried the Hobbypartz 5S 5000 20C packs. Mine weighed 618 grams. After 5 cycles the Cell resistance is ~1.9 to 2.4 milliohms.
http://www.hobbypartz.com/83p-5000mah-5s1p-185-20c.html
Joe Dunnaway
nonstoprc 05-23-2010 02:09 PM
My Turnigy 5s 5000mah 20C weighed at 666 grams. The two power wires can be cut short a little bit to save a couple grams.
