New Copter X 450 PRO V3 FBL heli
I got hold of the new Copter X 450PRO V4.
The new version has upgrades that make it more hard 3D capable.
The new head is almost the same as the FBL PRO but the new one
has a more cleaner finish. the bearings are smooth.. and the new swashplate
is much much better than the old PRO.. this one is contains a more smoother bearing and the actual finish is quite good..
The framework is the same as the old PRO. The only difference I found are the new servo holders. These have better finish.. the aluminum is somewhat matte finished and look to be made of a different kind of aluminum alloy...
other parts seems to be same as the OLD PRO
another upgrade is the tail boom. The new PRO comes with CF tail boom..
very nicely finished..
The tail assembly is another thing that I found to be upgraded.. and WOW what a big change. The quality of the finish is far better than the V1.. The L arm is not metal and the bearings used are really smooth..
and it comes with CF tail blades..
so basically the new PRO kit has all the parts in CF. and the new parts are far better quality than the V1 PRO...
the main blades are also Carbon fiber.. designed for the FBL system
Now the most impressive upgrade is Copter X Canopies.
The new 450 PRO has really good finished canopy.. Gelcoated
and pre painted fiber glass canopy...
The design looks like it came from its larger brother the CX600PRO..
ill get this little gem up and running to see what the new Copter X Pro V4 can offer...
