AERO DRAGON CALIDUS 50E,MADE IN CHINA ,FOR SALE
FEATURE:
1,Fuselage:1048MM
2,Rotor Blade diameter:1800-2000mm
3,Flight Weight:3500g
4,Flight Speed:10-100KMH
5,Power Motor:3.5KG E
6,Propeller:12*8-14*7
7,Power ESC:60-80A
8,Preratation ESC:4S 40A
9,Battery:4S 5000MAH,5s 4000MAH&2-3S800MAH,6S 32500MAH&2-3S800MAH
10,Servo:10KG 2 for rotorhead,5KG 1 for rudder and front wheel
Below parts is included:
1,Fuselage(fiberglass cowl,pvc canopy,wood&skin&painted tail,wood and Aluminum skeleton,Aluminum&painted landing gear,fiberglass wheel cowl)
2,Basla wood&fiberglass blades (a pair)
3,scale rotor head(anodized Aluminum,prerotation gear and prerotation motor included)
4,Two 3" PU wheels,one 2.25" front PU wheel and one tail foam wheel(prevent tail abrading)
5,two wire push-pull rods(for rotor head) and four cables(for front wheel and tail rudder)
6,One scale spinner(painted)
Below parts is not included:
1,Two 10KG servos for rotor head one 5kg servo for wheel and rudder.
2,The max thrust can arrived 3.5KG motor is OK,I can provide the High Quanlity & Reasonable Price's motor and ESC ,prerotation ESC is 4s 40A.
3,The battery is 4s-6s LIPO 5000MAH or more volume,4s is the best for the autogyro-rc.whatever the "S",the weight must be 500g or more to Distribution center of gravity.My calidus is scale,not the same as the gyro-one,so in my calidus the battery is placed at the front to adjust the CG,too light bettery is dangerous for flight.But take easy,there will be the CG hole at my calidus skeleton to check.
website is digging!
Video is coming,All the video key is:louis
1,Calidus LOW SPEED TAKING OFF AND LANDING PART1
http://v.youku.com/v_show/id_XNDkxMjU2NzUy.html
2,Calidus LOW SPEED TAKING OFF AND LANDING PART2
http://v.youku.com/v_show/id_XNDkxMjczNjg0.html
3,AERO DRAGON CALIDUS LOW SPEED AND HIGH ANGLE FLY
http://v.youku.com/v_show/id_XNDkxMzU2NDU2.html
4,AERO DRAGON CALIDUS TAKE OFF AND LANDING PRACTICE
http://v.youku.com/v_show/id_XNDkxMzQ4OTQ0.html
5,AERO DRAGON CALIDUS POWER OFF LANDING part 1
http://v.youku.com/v_show/id_XNDkxMzU5NTY0.html
6,AERO DRAGON CALIDUS POWER OFF LANDING part 2
http://v.youku.com/v_show/id_XNDkxMzQwNDgw.html
More info please contact:[email protected],LOUIS HU
1,Fuselage:1048MM
7,Power ESC:60-80A
website is digging!
Aero dragon calidus 50E high angle flying and landing off (0 min 26 sec) |
<iframe height="385" src="http://www.youtube.com/embed/MsvUA9Ckl8k?rel=0&wmode=transparent" frameborder="0" width="480" allowfullscreen=""></iframe> |
AERO DRAGON CALIDUS LOW SPEED TAKING OFF AND LANDING PART1 (0 min 39 sec) |
<iframe height="385" src="http://www.youtube.com/embed/WFblDem8qHI?rel=0&wmode=transparent" frameborder="0" width="480" allowfullscreen=""></iframe> |
AERO DRAGON CALIDUS LOW SPEED TAKING OFF AND LANDING PART2 (0 min 24 sec) |
<iframe height="385" src="http://www.youtube.com/embed/qYWgmEFs79Y?rel=0&wmode=transparent" frameborder="0" width="480" allowfullscreen=""></iframe> |
AERO DRAGON CALIDUS LOW SPEED TAKING OFF AND LANDING PART3 (0 min 37 sec) |
<iframe height="385" src="http://www.youtube.com/embed/bI-LdtvUDsM?rel=0&wmode=transparent" frameborder="0" width="480" allowfullscreen=""></iframe> |
AERO DRAGON CALIDUS 50E POWER OFF LANDING PART1 (1 min 16 sec) |
<iframe height="385" src="http://www.youtube.com/embed/56XRSI7zm7k?rel=0&wmode=transparent" frameborder="0" width="480" allowfullscreen=""></iframe> |
