Please help!!!
NY
I have an aerohawk with a fully charged battery and for some reason i can only get 1 foot off the ground at max throttle. And the whole heli just seems to slowly wobble at max speed. Dont know if its cause of my main blades or what. And how tight should the main blades be screwed in?
Thank YOu in advance for any input
My Feedback: (18)
MO
Maybe try different gearing to achieve higher head speed. I had this same prob with my first FP Hornet and going up a few teeth on the pinion made a world of difference. Just be careful not to go to high cause you could overload and burn up your motor...[:@]
NY
I figured my problem out my main blades were just a little to lose so when i was in a hover they would kinda get ahead of themselves. THanks
