Real weird problem!
AL
I have the piccolo fun with a Hacko Brushless motor and controller and High Authourity tail motor. My problem is, if the pico board isn't on the heli , it works fine. But, if it touches the heli in any way, the tail motor doesn't work properly with the main motor. I can power it up but, it will not power up on it's own and counteract the spin from the main motor. Once again, if i take it off the heli it works, as long as the pico board doesn't touch the frame. I can move it around as much as i want and mount it to anything else, and it still works, so it's not a bad connection, but the moment it touches the heli chassis in any way , it quits working properly. Even through the sticky tape. I can mount the board on a spare frame i have and touch the new frame to the heli and it still quits working.What is the prob?
Hi Flying W,
Sounds like you have a nice setup.
I do not use the piccoboard, but I know a big group of people who do. You can go ask the biggest group of Piccolo uses this question.
Try posting the same question on the [link=http://www.ikarus-modellbau.de/ubbthreads/postlist.php?Cat=&Board=UBB1]Ikarus[/link] board.
