NEED HELP placing GWS RX and Gyro
I need some help. Maybe a picture if anyone's got one. Hummingbird with GWS RX and Gyro. Which way does the Gyro Go? and Where did you mount them at? Where did you put the mixer board also?? Any help greatly appreciated.
RE: NEED HELP placing GWS RX and Gyro
you have almost the exact same setup as I do. Got the heat sinks, LiPo, Shaft collar, HB Alum. Head, Except I went ahead and got the alum. swash plate someone said it would really help out. ? for you. Why did you place the main blades on top of the head instead of below ?
Forgot to add.... Thank You for your assistance.
ORIGINAL: Double-OZERO
Static Display and Testing
Those blades are broken and I wanted to see how they fit compared to the Carbon fiber blades I ordered on time.
Your wellcome
tomflier
