AeroHawk Wobble Problem
I have been flying my AeroHawk and have had a problem with serious wobble. It will begin to wobble and then just crash... NO control. It does this about every 3rd. takeoff... I am sure that nothing is broken in the rotor head and all... so what else could it be?
Thanks, Wes
Thanks, Wes
hi.i have had the same problem with my aerohawk.i changed the main gear and it works fine now.watch the main gear and you will likely see it wobble.it seems that they are not moulded straight.
My Feedback: (73)
WI
Hi,
first make sure your blades are some what tight. Not too tight, but tight enough so they don't move around too much. Then take each blade and move it forward so they create about a 45 degree angle between them and the head. Now carefully hold the tail and power up slowly, when you reach a pretty high rpm let off of the throttle. Now try to fly it. I found that when the blades move back to create a negative angle the HB tends to bobble around like its on a teeter totter. Hope this helps
