Electric RC Helis Discuss electric rc heli's such as the Piccolo, Logo 10, Logo 20, Hornet, Eco.
Cheap mods
Old 01-01-2004, 08:09 PM
Flying Weasle
Flying Weasle's Avatar
Default Cheap mods
Anyone have a Piccolo and tired of the tail rotor loosening up? Or don't want to pay 7.00 for a collar for your main shaft? Great Planes makes shaft collars that will fit. Put one on each side and it takes care of that. They also have some that will fit the main rotor shaft. They are 1.29 for 4. Instead of the 6.99 or more other people charge for collars. And they have a larger screw so it will have less tendency to strip out. You should be able to get them at your LHS.
And i have broken my 2nd anti rotation arm. So i made an aluminum one. Shouldn't happen again.
ID:	86855   Click image for larger version
ID:	86856   Click image for larger version
Old 01-01-2004, 08:58 PM
VinceHerman
VinceHerman's Avatar
Default RE: Cheap mods
Woah. That third picture shows that you have tricked out your bird about as far as you can go and stay FP. Nice setup!
Here is a pic of my old ARL after repairs. I purchased a new, so this is now my spare.
Old 01-01-2004, 09:00 PM
VinceHerman
Um, how do you do the "click for full size" thing?
Old 01-01-2004, 09:09 PM
Flying Weasle
when you load the pic, load it in the "Upload images" at the bottom of the write window. It does it automatically.
Yea, i need CP. I also got tired of stripping fly bar arm control rod end screws so i trimmed the head and put in flat heads. I have a metal flybar that i took from my RapE tail pitch connector. I filed a small flat spot on each side where the control arm meets it so the screw hits a flat spot and gives more control and doesn't let loose. There are some really cheesy ways they have done things with these. I've done away with most of them.
Old 01-03-2004, 06:53 PM
drevil
Thanks for the cheap mods! I love stuff like this!
Here's one. Helihobby screws everyone by selling you $3.99 metal pinion gears for $6. I understand they need to make their money but the damn packages that the pinion gears come in actually say $3.99 LOL
They are nothing more than Orion Micro RS4 R/C car pinion gears that you can probably order from tower hobbies for even less than the 3.99
Mike
