How to change rotorhead on aerohawk
I must change the lower part of the rotorhead on my aerohawk. I have removed the pin going through the hole in the mainshaft, but I still can't remove it. Is the rotorhead glued to the mainshaft? Is it a good way to take off the rotorhead without destroying other parts on the heli?
RE: How to change rotorhead on aerohawk
I was wondering the same thing about my hummingbird.. Are these the same machines, clones of each other? Anyway, you have taken the links off, right? If so, I would at that point attempt to carefully rotate the rotorhead slightly while holding on to the main gear, but that's just what I'd try next, perhaps someone who knows better than me will give you safer advice?
Jason
Jason
