my Aerohawk has come but i need help please
hi guys the little chopper has come its my first ever chopper (im a car guy so i do have a some rc knoledge) i set it up like the manuel says and i have fixed the training kit to the ski's and had a little go to set the the trims
BUT!!! i have got 3 problems which are
the tail roter seems to be spinning to fast maing the chopper turn clockwise what can i do to stop it the trim is full
the chipper wont lift off the ground dont seem to be enogh lift? how do i reslolve this
the chopper is sliding to the left when facing away from me? messed with the trim but i ahvnt resolved anything
these 3 things seem to be a big problem for a little learner like me an im guessing i cant really learn to fly with out them sorted so please sort me out fellas
cheers
jon
p.s. can some 1 also explain to me what the gyro actuly dose as im a total newbie and i dont have a clue about any of your heli lanuage
cheers
jon
WA
RE: my Aerohawk has come but i need help please
Well I can't really help with your problems but i just got an Aerohawk yesterday. I have the same problem with it sliding to the left as well. I can tell you the gyro tries to help keep the tail in one position. You can test this buy turning on the Tx and then turning on the heli. Next turn the tail boom but make sure your hand is out of the way of the tail rotor because if your gyro is working proberly it should turn the tail rotor.
Hi
I'm using Dragonfly so can't really help you on Aerohawk but some of the behavior are similar to all chopper.
If your main rotor blade spin clockwise (Seeing from top view), your tail will try to go right (Seeing from top view again or from rear view). To counter your tail movement due to main motor torque, the tail rotor will generate thrust that pushing your tail to the left.
With both combination, it is inheritantly that clockwise spinning chopper will tense to drift to the left.
I not sure what is your Mixer or your ESC look like so I can't really recommend what to tune. U need to reduce the tail rotor torque/thrust in order to reduce the spinning. How to reduce will depend on what ESC/Mixer/Gyro u have.
As for not enough strength to lift up, First thing to check is whether have you fully charge your batteries?
As for gyro, I think Little_Syco pretty much explain it.
Super-Hornet
Super-Hornet
Sounds like you have answers to two of your questions. The remaining question is how to adjust the tail rotor spin.
First try to set the trim all the way to the opposite side before you turn on the heli. Then after the red LED comes on, adjust the trim. If you can do it this way, it is easy, and no messing with anything.
If this still isn't enough to trim out the tail rotor spin, you need to look at the 2 pots on the mixer board. Taking this from another thread:
If you have too much tail spin, you should be able to turn the gain counter clockwise to get you into a trimmable region.
Good luck.
Heli_fly
ORIGINAL: glennT
There are 2 pots on the mixer board. The front most for gyro sensetivity, the next for gyro gain. Clockwise to adjust up for both.
If your not seeing enough tail authority from a new motor, the motor is bad. Turning up gain will only kill it sooner.
Good luck.
Heli_fly
