Go Back  RCU Forums > RC Helicopters > Electric RC Helis
 Aerohawk Tail problems >
Electric RC Helis Discuss electric rc heli's such as the Piccolo, Logo 10, Logo 20, Hornet, Eco.
Old 02-07-2004 | 01:21 PM
Default Aerohawk Tail problems
On my last flight I crashed and hit the ground pretty hard....the tail motor kept spinning at full throttle while it lied on the ground with no throttle input from my remote control..I disconnected the helis battery and reconnected it again and at this point the light would never turn back on and the tail motor wouldn't respond...can anybody tell me what the problem may be? Is the tail motor dead? Is the board malfunctuioning and what can I do to fix it? Thank you guys very much for your help!
Old 03-21-2004 | 01:41 AM
Default RE: Aerohawk Tail problems
ive read you can heat up the gyro(large rectangular chip on front of board same side as mix and gyro adjustments)with a soldering irion ,or simallar,and it will sometimes make the red light come on but i dont think it will work right though.
interested to see if it may work for you
good luck
Old 03-21-2004 | 02:24 PM
Check the Tail motor before you do anything to the main board
You can desolder the Tail motor - the check it with a battery + a couple of bits of wire
