better lipo sugestions please!
I have a li-Polymer 1300mah/7.4v thunder pack. I get about 15 minutes of flying on it mabey. I want longer flight but dont want to blow andy chips away. I have a pixi20p for the main and a pixi7p for the tail. My main does have a 5amp fuse on it. any sugestions would be great. Escpectially Pros and Cons.
RE: better lipo sugestions please!
Jus, 1300mah is a gd choice. Some have used kokam1500mah with success and some find it too heavy. Its a trade off if u get higher capacity. But try not to go over 1500mah. it'll probably be too heavy to hover properly. Juz my 2 cents....
I'm using a Thunder power 7.4v, 2100mah and have had very good luck with it. I am getting about 20 to 25 minutes of flight time.
I payed $80 Canadian for mine, that's about $57 USD. I have read where people have used 3 cells, but they burnt up there boards. That's why I went with the 2 cell (better safe then sorry). I don't need a 3 cells anyway, I has all kinds of power with 2 cells.
Thunder 6C 2100 mAh 2S1P 7.4V
is this what you have? I can get it for 64.99 canadian. I wasnt sure if it was 2 cell. what does the 6c mean? I hope not 6 cell.
this is the site I found it at.
http://www.zebrahobby.ca/cgi-bin/cp-...:miscellaneous
It looks the same as the one I got. I don't know what the 6c stands for. I just looked at my battery and it doesn't say anything about 6c. If it is the same as the one I got, that's a good price. Thanks for the link.
I just looked at that battery again, the plug-in on the end is different then mine, but other then that it is the same
there is no actuall conectors on that battery....it is shrink wrap I believe. just for shipping perposes. I think I will go with that pack as my main and use my other as a back up. I am burning motors up like crazy....not too big of a problem though. I am about to try a different motor. Much bicgger but same gear and everything is already on it. Ill let everone know how it goes.
What would I want for a discharge rate? whats the differences in them? some are 20c discharge and some are 3c discharge and there are otheres too? I get confused on this stuff!
Justin,
3s lipo pack (11.1V) may fry pixie-7p. Also you dont want to overheat J250 motor.
You can get 2s-1900mah lipo with high discharge rate here: http://www.tppacks.com
TP1900-2S.
Thunder Power "Super Dynamic Power" LiPo Electric Flight Pack
1900 mAh, 2 cell (7.4V), 16 gauge wires
Rating: 8C-10C Continuous Discharge
Dimensions (wt): 45mm x 70mm x 13mm (80gm)
Price: $49.95
Regards
TP1900-2S.
Price: $49.95
Regards
