Jabo 2 and simulator with Silver Zhen Hua
Hi, I have searched and I cannot find anything related to this control.
I have a Jabo 2 with the silver Zhen Hua PCM-4ch controller. I am trying to get it to work with FMS, I have tried it on both my XP and ME machines and have had no luck. I tried the PPJoy on my xp machine, but it gets as far as reading, with a funny beeping noise, so I cannot use it on FMS.
On ME, PPJoy does not even find the control.
Also, does the transmitter need to be on, or can it be off whilst doing this.
I hope you can help me out,
Josh
Josh
RE: Jabo 2 and simulator with Silver Zhen Hua
Before you ask, I searched through the forum, and found the topic about the zenhua, but it is about the black control on the Jabo, not silver on the Jabo II.
Also, at first I got it working with Tru-Flite 3D, but then I used the control pon the helicopter, and I have now tried it again on Tru-Flite, it says "No Transmitter can be found" and it terminates.
Josh
Josh
CA
http://www.rcuniverse.com/forum/m_19...tm.htm#1985939
Scroll all the way down, there's a procedure for Zhenhua and FMS.
hope this would help.
CA
ORIGINAL: joshiestevens
Josh
Josh
The transmitter doesn't need to be on while running FMS.
i tried that and no luck. Maybe thats for the old style black zhen hua control. I actually got mine from china, so it is the newest zhen hua control. The wierd thing is that the transmitter works fine with Tru-Flite 3D which is a simulator, but it does not work with FMS.
I hope you can help, and I am sorry if I reply late, as I am in spain, and can only get on the web when I visit the internet cafe.
Josh
Josh
I got it all working here... I have the silver control. Also though I do think True-Flight 3d is very crappy. It works fine. We're using Xp Pro. If you are going to use FMS download FMS 2.0 Beta 7 not the newest. You also have to setup PPJOY for FMS it work correctly.
Hi!
Follow this instructions and all of you will be able to play fms with jabo controller.
http://www.radio-controlled-toys.com/jabo_fms.htm
I am having the same problem with my silver transmitter and PPjoy and FMS.
I have followed through the instructions on the link above, but i am not getting any beeps in PPjoy and there is no response to the transmitter in the calibration section of FMS.
The transmitter is switched on.
You have to follow the instructions to the letter....
[link=http://www.radio-controlled-toys.com/jabo_fms.htm]RC Helicopters[/link]
I had the same problem, the connector on the back of the transmitter was the problem, i got a new one from Maplin for 99p and soldered it in, now its fine.
i got the same problem before, i asked my provider www.xmseller.com
he tell me to take the battery out from RC, then it worked, try it .
