dragon fly tech support
newbe wants to go li-po. I just got a dragonfly and the flight times are pitiful. I wanna li-po to run a stock bird. Wich one should i get.
2Cell 1200-1500mah Li-Po should give you 15-20 min.
Always give the heli a rest for 8 - 20 min so the electics can cool down. I don't try to charge the LiPo's straight after a flight as they are still quite warm. Quite often I'll pop the warm cells into the fridge for 30 min.
Only use 3C if the electrics can handle 11-12 volts (brushless motor and high freq. tail ESC) .
My Feedback: (9)
Yea good call I use a 2 Cell 1320MAH get about 15 to 20 mins of flight time. Then I charge em up providing they are not too warm. After about and hour and a half of charging everything is cooled down and we are good to fly again.
