Go Back  RCU Forums > RC Helicopters > Electric RC Helis
 Smartech Aerohawk tailproblems >
Electric RC Helis Discuss electric rc heli's such as the Piccolo, Logo 10, Logo 20, Hornet, Eco.
Old 09-20-2004 | 04:47 AM
Default Smartech Aerohawk tailproblems
Hi you guys!
I have a problem with my Smartech Aerohawk...
The tailrotor doesn't seem to be turning when i control it - it does however turn if i hold the helicopter in the main rotor and start it (then the whole body turns, and the tailrotor starts to spin out of control).
This proves that the motor works fine, but there's no contact to it.
Do any of you know this problem, and how it's solved? I miss my chopper...
Thanx!
/ F
Old 09-21-2004 | 12:46 PM
Default RE: Smartech Aerohawk tailproblems
Did you try adjusting the mixer and gain?
Old 10-02-2004 | 05:47 AM
How do I do that?
Old 10-02-2004 | 03:56 PM
Check the wires from the board to the receiver. I think that the tail channel is not connected right.
Old 10-03-2004 | 10:56 AM
I've now tried to check all the wiring on the board, and everything seems to be in order...
I've tried to turn the two screws on the PCB to see if that changed anything - and it didn't :-(
The motor seems to be working (since it turns if I hold the chopper in the main rotor and give it power - then the body turns, and the rear-rotor spins out of control).
Do you have any other ideas of what it could be?
Old 10-04-2004 | 09:05 AM
What caused this problem??
gyro is probably out.
The 'screws' you talk about are the tail and the gyro mixing pots.
With the cables in your right hand, the gyro pot is on the left and the tail pot is on the right.
There are some images and similar discussion over at a thread titled: 'Need help w/ Aerohawk board. '
I am searching for a good source for Ceramic Gyros, I'll let you know if I find it.
