Shogun 400 servo mounting
VA
I'm using HS-55's in my Shogun, and the screws that come with the servos are too small for the pre-drilled holes in the frame. Should I try to find machine screws and lock nuts small enough to fit (about 0.058 inch / 1.5mm diameter), or use larger servo or sheet metal screws? I'm concerned that the frame isn't thick enough for sheet metal screws to hold well. How did you mount your servos?
