T-Rex 450 - Post your setup here and comments
Hi !!! I just bought a T-Rex 450X V2 and I need some advice for the setup (3D setup)
I will use:
4 Hitec's HS-55 servos
Hitec Electron 6 channel
Phoenix 25 ESC
TP 3s 2100 mah
GY 401
Futaba 8UHPS
For the motor I'm thinking in the WARP4-3T or should I use the 4T ?
The WARP4 is a good choice for 3D? Does is fit the T-Rex mounting?
Please post comments and your setupo below for the T-Rex and give me some advices !!!
Thanks in advance for all !!!!
I will use:
Phoenix 25 ESC
TP 3s 2100 mah
GY 401
Futaba 8UHPS
RE: T-Rex 450 - Post your setup here and comments
Still building it......
Trex 450 XL (CDE) CCPM
Align 400LF 3200KV
Align 25A ESC
3x HiTec HS-55
1x Align 9g
MaxAmps 2250 3s LiPo
Futaba 7CHP
HiTec Electron 6
Real Flight G3 is on the way also (Total newbie)
DW
Align 400LF 3200KV
Align 25A ESC
3x HiTec HS-55
1x Align 9g
Futaba 7CHP
HiTec Electron 6
DW
Where you gonna use the Align 9g?
Can I use the HS-55 all over the heli? even collect and tail?
What about the motor? I'm thinking in the WARP4 3 or 4T ?
Does the Align 400LF 3200KV will provide enought power for 3D?
Thanks in advance
Thanks in advance
Im getting my t-rex very soon. Here will be my set up:
multiplex 480-4d
cc 35amp esc
hs55 and hs50(tail)
futaba 7ch
futaba pcm reciever
tp 2100
Satkunas--As fas as hs55 all around, you can dso that. Usually you want more speed on the tail , so many ppl run the hs 50 on it.
Later
multiplex 480-4d
cc 35amp esc
hs55 and hs50(tail)
futaba 7ch
futaba pcm reciever
tp 2100
Later
Nitro, the HS-50 can handle the tail? I mean, I know that the 50's has more speed, but waht about the torque? Don't I need some torque for the tail also?
Thanks in advance
Thanks in advance
HS55 will do just fine on the tail.. I've seen people use HS56s as well. Advantages? Cheaper, more sturdy.. Disadvantages? Slower piro rate (which is still more then you'll ever need) unless u're looking for 10revs/s (exaggeration). I'd recommend getting rid of your Align 9g servo since it gave me twitchy tail... also, if you go from HS50 to HS55 (or 56) you will have to adjust your gain. Mine went from ~60% to ~83% in HH mode on an Eclipse 7.
"Does the Align 400LF 3200KV will provide enought power for 3D? "
No.. the Align motor will do just fine for simple hovering, FF, circuits, etc... but for serious 3D I'd go with something else.. search the forums for other ppls opinions/setups as those vary from one to another. Also, make sure your ESC can handle at least 35A if doing 3D.
Just my 2c
Just my 2c
OK this is my TRex as it sits in the other room now. I have bits on back order and I will add them to the list as they arrive.
Align TRex 450X
Align 11.1V 1800mAh battery
Align 400LF Brushless motor
Align 25A Brushless ESC
Robbe G-200 Gyro
Align RC-Rx6M Reciever
Align RC-9X Servo's
Align Super Micro servo (tail)
Align V2 ally Swashplate
Align ally Flybar Control levers
Align ally Flybar Control set
Align ally Flybar
Align ally Main Rotor Head
Align ally Blade Grips
Align ally Mixing Arms
CF look Tail Blades
CF look Flybar Paddles
The new 'improved' Main Gear (one with cooling fins).
Custom Paint job
JR X-347 Tx.
Headspeed governed 2200rpm
Pitch Normal linear 0 to +11
........Idle 1 linear -5 to +11
........Idle 2 linear -11 to +11
I think thats it. As I said I have more bits on back order so I hope to be able to add some more soon.
I'm also having trouble with my heli during hard moves, struggling to maintain the governed headspeed so there could be a new motor,esc and a kokam 2100 coming home soon.
Jon
Align TRex 450X
Robbe G-200 Gyro
Align RC-9X Servo's
Align ally Flybar
CF look Tail Blades
Custom Paint job
JR X-347 Tx.
Jon
TX
New 450XL CCPM
ALL Stock
Mega 16/15/3
PHX 45 v1.16
poly Quest 1500 20C
3x GWS Pico standards
Blue bird tail servo
GY401
Hitec slim 6 Rx
Fut 9z WC2
I have flipped the Rex using govoner mode and "V" curve mode... "V" curve is the way I like it.
Norm = 1760
Idle 1 = 1920
Idle 2 = 2105
Loven every minute of it...
ALL Stock
Mega 16/15/3
PHX 45 v1.16
poly Quest 1500 20C
GY401
Hitec slim 6 Rx
Fut 9z WC2
Norm = 1760
Idle 1 = 1920
Idle 2 = 2105
Thanks for the Replies..........
Ichibon_KoKojin How many amps the Mega is delivering?
About the motor, Do you think the Mega 16/15/3 is the way to go with a Phoenix 35? Or maybe the WARP4-3T or Align 420LF 3200kv?
I'd like to have a real 3D machine, so the motor is the heart of it !!!
Thanks for all
Thanks for all
CA
Greetings,
Trex 450X v2
was Box stock kit, added XL tail rotor and XL flybar box
3 HS56 servos
1 GWS naro F-HP BB rudder
Futaba 240 gyro
Hitec 8ch RX
Optic6 TX
Align 430L w/10 tooth
Align 25A esc
MK2 lipo 2200/12C
Wood 315mm main blades
head speed tach reads 2230rpm
THCV 1 2 3 4 5 throttle curve
normal 5% 84% 84% 95% 100%
ST-1 100% 90% 80% 90% 100%
PICV 1 2 3 4 5 pitch curve
normal 34% 47% 65% 75% 100%
ST-1 0% 20% 50% 75% 100%
i added program mixer master is ch2, slave is ch3. forward cycl adds 15% more throttle and aft adds same to help control weight of nose and tail.
my pitch range in ST-1 is -10 to +11
she is very stable, I have been doing rolls and loops with ease and working on my stall turns and hope to fly often!
been looking at CCPM conversion... [8D]
Trex 450X v2
3 HS56 servos
Futaba 240 gyro
Hitec 8ch RX
Optic6 TX
Align 25A esc
MK2 lipo 2200/12C
TX
got hooked with a dragonfly 36 and now i am ready to take the plunge and get a trex. i am looking at the "dream package that is almost at the bottom of this page.(http://www.helihobby.com/html/trex_helicopter.html) does it look good? is there any changes you'd make to the package. let me know. won't be getting it till tax time. (huge refund this year) i just got tired of waiting 2 weeks for parts and having a crappy heli after working on it so hard. very poor quality to start with.ready for a real piece of art/machinery.
CA
I too started with the 36, the Trex is a jump forward in my opinion. The 36 taught me well and all the replacement gear went directly into the 450x. I'm 48yrs old, so the bright neon colors really help me with orientation.. [8D]
the Reflex XTR makes rainy days almost a good thing... hehe
edz
edz
My Feedback: (36)
My T-Rex is under construction. Here's what I have so far:
450 XL eCCPM
Mega 16/15/3
Castle Creations Phoenix 35
Futaba R146i PCM receiver
Futaba GY-401 gyro
Futaba S9650 digital tail servo
Hitec HS-56 servos on cyclic
Thunder Power 2100 mAh Pro-Lite
Here are my upgrades so far:
Align carbon fiber frame
Align aluminum swashplate (grey)
Align aluminum blade grips (grey)
450 XL eCCPM
Mega 16/15/3
Futaba GY-401 gyro
FL
T-REX 450XL
Futaba 6EX-H TX
R-146iP RX
S-3103 servos
Futaba GY401 Gyro
Castle Creations Phoenix 35 ESC
Mega 16/15/3 motor
Tanic 3s 2220mah
Check out READYHELI for the se kit without motor and esc.
http://www.readyheli.com/index.php?m...roducts_id=102
FL
^^^^definately recommend www.ReadyHeli.com ...ask for John and tell them Jack sent you great guys...great deals on T-REX's
TX
now that i compare the two , the helihobby package has tx, lipo, charger, deans antenna and connectors. i think i'll stick with them for now. that's a really hard deal to beat.
T-Rex XL
Walkera servos
Walkera gyro
Walkera Dragonfly 36 tail
Walkera brushless
Walkera TX/RX
Walkera stickers everywhere
Walkera logo everywhere
just kidding .... my Dragonfly 36 wasn't bad, but I crashed it two times because of radio failure and upgraded
to an T-Rex SE with Gy401, 4xHS56 and Futaba 7CH
Walkera servos
Walkera gyro
Walkera brushless
Walkera TX/RX
FL
they can do better than hellhobby....trust me.....just tell them jack sent you.... they will throw all the goodies in for you to make it complete...
Rotorworkz G4 frame
Heliworkz elevated tail
Mega 16/15/3 w/ CC25
3xHS56
HS81 tail (fast and torquey)
GY401
ProLite2100
SombraLabs Shadow 3 (DSP and crystalless)
Heliworkz frame, HV frame, Align CF frame
I use a lot of different motors, gyros, ESC's and whatever else just to see how well they work and to keep from being bored. There are two other Rex's that aren't being shared yet, one is a 2 blade flybarless and the other a 3 blade system.
Hi all.
I have just finished putting together my t-rex 450x. I am now in the stage of test flying it. I have ran into a bit of trouble though. As i power up and get to about 1/4 throttle it starts to spin round like i haven't got enough yaw set in. I have tried different setting on the tail but i just seem to run out of movement for the tail. Does any one know how I could fix this. Please email me and let me know.
Hi,
I'm just putting together a basic T-REX 450 using parts from my crashed Walkera #60 (nothing wrong with the #60, just difficult to get parts). The first time is spun it up, my T-Rex did the same as yours - this was a warning sign that the belt pulley at the fuselage end was about to go. The top of the pulley was working it's way off and allowing the spindle to turn without the pulley. It evenually fell off, together with the belt - lucky I was on the ground. This seems to be a weak spot, and Ive ordered the metal upgrade in the hope that it will be cured. If it's not that, then the Walkera had the same problem, but this time it was just the gyro reversing switch needed to be set to 'reverse'.
Hi, I have had my t-rex se set up to fly in normal mode from a guy that I met at a local fun fly meet. Ever since then I never have figured out how to set it up in the transmitter to fly in 3d mode. Can anyone tell me or point me toward a forum of how to set up the transmitter compter and helicopter to fly in 3d and upside down?
I have the t-rex 450se and the spektrum dx7 (heli edition).
David
David
