Direct or belt drive tail rotors
Well after all the problems everyone..and myself have had with burned out tail roter motors; is there a good electric chopper out there that uses a belt drive or a gear drive off the main motor? And if so is it a whole lot different to fly?
CT
the trex, and the ark 400 both have belt drive tail rotors, and both are excellent elec heli's
also the shogun has a gear driven tail
and as far as being a whole lot different to fly what is it your comparing it to? if your comparing to a micro heli, yes they fly a heck of alot better.
GA
The shogun uses a shaft driven tail rotor.
There are pros and cons to both.
The tail motor driven ones suffer from burning up and a little lack of tail authority. The advantage is that tail strikes usually dont do much.
The tail shaft driven ones will strip the gear if you get a good tail strike. There are upgrade metal gears though.
