Go Back  RCU Forums > RC Helicopters > Electric RC Helis
 Eclipse 7 Setup Question... (or any Comp. Radio) >
Electric RC Helis Discuss electric rc heli's such as the Piccolo, Logo 10, Logo 20, Hornet, Eco.
Old 08-19-2005 | 08:19 AM
Default Eclipse 7 Setup Question... (or any Comp. Radio)
Hey guys. I have a question about setup of my Eclipse 7 radio but I don't think it is specific to the radio itself.
As I read through the manual there is 1 TX settings that I am a bit puzzled by.
GYRO setting. This is used to "automatically control the gyro's gain in different modes".... Is this gain the same as I would adjust on the POT of a GY401 for example? I am having a hard time understanding the correlation. Do I need to set this in the TX if I have an HH Gyro? If so, can someone explain the relationship?
Thanks!!
Old 08-19-2005 | 12:50 PM
Default RE: Eclipse 7 Setup Question... (or any Comp. Radio)
The GY401 has to be set via TX, there is no way to do it on the gyro it's self (in terms of gyro gain)
On the Eclipse 7, there is several different flight modes. Generally, if you setup one flight mode with a gyro gain over 50% and one flight mode with a gyro gain below 50%, switching between the two will allow you to switch between AVCS and Normal(rate) mode. Then simply adjust gyro sensitivity as nescesary in whatever mode you pick. For example, I switch between normal mode and ST1 mode to switch gyro operation.
Also, the gyro must be powered on in AVCS (heading hold) mode and then switched. So, for example, if you've got norm set to 75% gyro gain, turn the transmitter and gyro on in that mode, then switch to rate mode if you need to on ST (or whatever you set it to). It would've been a whole lot easier all things considered if the eclipse 7 had a gyro switch, but alas, you gotta work around such things
The futaba gyro instructions are awful, theres a good guide online, have a look at this:
http://www.coloradorotorheads.com/articles/401.htm
It should help explain alot of stuff.
Old 08-19-2005 | 01:05 PM
That is EXACTLY what I was looking for. Thanks Credence!
Completely makes sense to me now.
Awesome!
Old 08-19-2005 | 02:33 PM
No problem
