Go Back  RCU Forums > RC Helicopters > Electric RC Helis
 How to track blades please help! >
Electric RC Helis Discuss electric rc heli's such as the Piccolo, Logo 10, Logo 20, Hornet, Eco.
Old 08-21-2005 | 01:17 PM
Default How to track blades please help!
The blades in my deagon fly 36 arnt alignes I thing hey need to be tracked i guesswhen i lookd at the blades while it is spning they are up and down so how do i fix it?
thank yiu
Old 08-21-2005 | 03:36 PM
-pkh-'s Avatar
Default RE: How to track blades please help!
You need to put different color tape near the tip of each blade, use the same amount of tape and put it the same distance from the tip of each blade so you don't mess up the blade balance. Hover the heli and note which blade is high. Then you can either bring the low blade up, or the high blade down. If the ball links go to the blade grips on the leading edge side of the grip, then tightening the link will bring the blade down, unscrewing the link will bring the blade up. If the ball links go to the blade grips on the trailing edge of the grip, it's just the opposite...
Old 08-21-2005 | 05:25 PM
if you cant hover yet, it's okay to pin the heli to a table with a board across the skids and some books holding it down '_;
