brushless in blade
VA
I am ready for a brushless motor.I have the motor and speed control.Can i Plug the speed control where the brushed main motor was and plug the battery ionto the speed control?Love my 2 blades.I made a night flier by gluing the little red pop light from Walmarts fishing bobbers on the end of the blade{leave room to turn on} and amall gloqw sticks on the main gear and boom. Dave
hey,
I think this site has some information for your problem
[link=http://www.helihobby.com/html/separate_electronics.html]http://www.helihobby.com/html/separate_electronics.html[/link]
greetings,
Aap
greetings,
Aap
CT
if the blade is similar to the honey bee 2 ( which i have owned at one time) then no you cannot just hook up the controller to the motor output on the 4 in 1 box. To go brushless on the main motor you have two options, 1st option a2p posted a link showing how to go with all seperate components for the heli ( expensive alternative) 2nd option is you have to take apart the 4 in 1 box of the blade and tap into the channel 3 signal wire for the brushless controller. I believe there are posts on this forum with instructions on how to modify the 4 in 1 box. But i think the picture links in that thread are all dead.
