Blade CX wobbles violently
My Feedback: (9)
SC
I have only flown this chopper about 5 times and have replaced the upper stabilizer bar once. I flew it a couple more times with no problems. Then I go to fly again and as soon as it lifts off, it starts to wobble violently as if the gyro is not working. I have checked everything I know to check, any ideas or similiar problems??
NY
RE: Blade CX wobbles violently
sounds like your flybar is in wrong. try turning it 1/4 turn, you should be able to do this without unhooking the linkage. from top veiw the flybar should lead the blade while rotating.if not it will wobble till it tips over.
