My new TREX 450SE
My new TREX 450SE
See my new heli as shown
I bought this heli from [link=http://www.pinnaclemodel.com]Hong Kong [/link] 2 weeks ago and I love this heli very much! The price is also great, just US$433 with ESC and BL.
SC
RE: My new TREX 450SE
I see you mounted your ESC on the right side of the heli. I was thinking of mounting mine right under the frame of the motor. Did you put the RX behind the motor like the book said? Did you have to range check the heli?
smallplanes
smallplanes
I put the ESC at right side is to provide more air flow from the rotor to ESC for better cooling. And, I aill avoid to put the ESC right under the frame to avoid damage due to landing on rough surface.
I put the RX at Top-front (On carbon plate), not behind the motor. I did range checked and it is satisfy.
So far so good!
So far so good!
KS
Ivan,im going to get a T-REX from pinnacle..is the 184.00 for the digital servo and 401 gyro worth the money?
What all did you buy for you'res as far as servos,reciever and extras...I want to get everything in one buy so I can get in the air quickly.
Will an airplane 7 channel reciever work in these helis(Futaba FPR 127DF) or do I need some sort of mini reciever?
Thanks!
Thanks!
SC
Thanks for the info. I have another one did your ESC (align i guess) come allready programed for your heli? What i mean is when i put ends on the motor and ESC and plug them together will it be setup . I have a 430L motor and a Align 35a ESC.
Thanks for the help
smallplanes
Thanks for the help
smallplanes
ORIGINAL: P-40LUVR
Thanks!
Thanks!
Hi,
The 401 + S9650 worth the money. I have my own FF9 radio already, so I just buy 3 Esky micro servos and S9650 for rudder. All stuff like LiPo, and LiPo charger is up to you. Mine is 11.1V 2200mAH LiPo. Hope this help!
One more, your Futaba FPR 127DF receiver is ok for basic flying but may be too heavy for aerobatic. You may buy the mini one later as upgrade.
ORIGINAL: smallplanes
Thanks for the help
smallplanes
Thanks for the help
smallplanes
The ESC came with the kit need programming by yourself. For example, you have to set brake, driving frequency and soft start and cut off voltage. And of course, the reverse direction of your transmitter and revolution direction of the BL motor. I would suggest you do the setup before you engage the motor into the heli to avoid danger situation.
Hi, I bought the real carbon fiber 325mm blade from [link=http://www.pinnaclemodel.com/index_eproduct_view.php?products_id=400]Pinnacle[/link]. The quality is awesome with the price just US$28.2.
