crashed blade cx need help with outer shaft
ME
crashed a cx today and it needs a new main gear. question is when you put it back together where does the upper lock collar go? do you put it a couple of thousandths away from the top bearing in the frame or higher up near the swash plate.
ME
RE: crashed blade cx need help with outer shaft
found out where the lock collar goes. it goes a couple of thousandsths away from the bearing closest to the frame.
