Go Back  RCU Forums > RC Helicopters > Electric RC Helis
 Stop The Spinning >
Stop The Spinning
Electric RC Helis Discuss electric rc heli's such as the Piccolo, Logo 10, Logo 20, Hornet, Eco.
Stop The Spinning
Old 10-16-2006 | 10:59 AM
Default Stop The Spinning
I have an MX-400, Spektrum DX-6, and GY-240. I'm new to helis so everything is foreign. Whenever I idle up the copter it spins like crazy to the right. The Gy-240 manual is not that clear for a beginner. It's frustrating trying to fix it without know exactly what to fix. Any suggestions would be appreciated. Thanks
Old 10-16-2006 | 11:40 AM
Motions's Avatar
Default RE: Stop The Spinning
You need to reverse the gyro. Is the rudder stick input correct? If not, you need to reverse that too.
Old 10-16-2006 | 08:56 PM
Also make sure you have no mixes, revo, etc. that effect the rudder. The gyro sees this as an instruction to yaw the helicopter in the direction of the mix. This assumes HH mode.
Old 10-16-2006 | 09:56 PM
yup look for some switched that says reverse or look in the manual for the switch and it should stop spinning and actually work
Old 10-18-2006 | 10:49 AM
Thanks guys. Reversing the gyro worked.
