Go Back  RCU Forums > RC Helicopters > Electric RC Helis
 Official Bladerunner Micro Mosquito Thread >
Electric RC Helis Discuss electric rc heli's such as the Piccolo, Logo 10, Logo 20, Hornet, Eco.
Old 12-24-2006 | 06:59 PM
Default Official Bladerunner Micro Mosquito Thread
Hi, I just got a micro mosquito from my Grandparents for Christmas. I am thrilled with this little bugger, its about 50 times easier to fly than the PiccoZ. I am planning on modifying mine. So, if anybody knows any good mods for the MM, please post them here.
This is what Im planning on doing for starters.....
-Solder on a higher mah Li-Po battery
-Put a larger motor on for the tail so that I can get faster forward flight.
Im not really sure how great this thread will strive, but its worth a try
Merry Christmas Everyone, Alex
Old 12-24-2006 | 07:09 PM
Jellyson's Avatar
Default RE: Official Bladerunner Micro Mosquito Thread
Well, I put a tiny piece of solder on mine to bring the nose down a bit and give it more forward thrust.
I love the green headlight eyes, I turn out the lights and fly it in the dark.
Maybe a strobe system?
Old 12-26-2006 | 02:54 PM
I got one as an early Christmas gift and it's a blast.
I've seen a few complicated mods listed on other sites that I didn't bother with,
including adding bearings to the main shaft.
Adding a touch of weight to the front, and the optional larger tail fan improve forward flight characteristics.
(That stuff should be included with the kit)
There's one called the "Toilet bowl mod" that's pretty painless:
Because of the long and flexible main shaft, they're very susceptible to the pendulum (or Toilet Bowl) effect.
You can shorten the main shaft, and the distance between the rotors, fairly simply.
Essentially raising the center of gravity and giving the tail rotor a little more mechanical advantage.
Pop off that little bit of silicone rubber tube that retains the upper rotor on the mast.
Slip the upper fan off the main mast.
There's a sleeve on the main shaft that acts as a spacer between the upper and lower fans.
Remove the sleeve and cut it down to 15 or 16-mm (roughly in half).
The top end of the mast is cut to a "D" shape to drive the upper fan.
put the spacer back on the mast, and with an Xacto knife, bevel the face of the main mast
so that "D" shape continues down the mast to just a hair above the spacer sleeve.
Put the upper fan back on the mast and replace the silicone tube retainer.
You might want to lube all the moving parts while you've got it apart.
Once it's assembled, you'll want to make sure there isn't too much play in the main shaft.
Get at eye level with the bird and raise up the gears by their hubs.
There should be enough play so nothing binds,
but not so much that the drive gears can walk off the pinions.
It's a little more stable, forward flight is improved, and there's fewer boom strikes.
(Thanks to Chevy6600 for this mod)
The only other thing I did was take the spring off the throttle lever in the Tx
(and paint the arrow side of the plug white)
I've gotten more air time with this in 2 days then I have with the TRex in the past 2 months.
Old 12-26-2006 | 03:01 PM
Jellyson's Avatar
Wow. I had no idea.
Where did I put that thing?
Let's see, where can I get some teeeeny little bitty brushless motors...
Old 12-26-2006 | 03:09 PM
I know man,
can you see putting that much time into a $70 heli?
When mine gets tired I'm gonna take it out to the shotgun range and try my hand at some REAL sporting clay.
I'll post the results on YouTube
Old 12-26-2006 | 03:27 PM
Jellyson's Avatar
ROTF!, yeah that should do it...
Old 12-27-2006 | 08:42 PM
ORIGINAL: Jellyson
Wow. I had no idea.
I like your idea, Im gonna start lookin around for some tiny brushless motors and ESC's. Im going to attempt the main-shaft mod tonite.
Old 12-28-2006 | 09:39 AM
if you're interested. there's a couple of other mods in this thread, the author allegedly is a rep for the mfg.
http://www.rcgroups.com/forums/showp...&postcount=117
