Eagle50/22E Flybar Attachment and 4-in1.
How do I tighten the flybar on the Eagle50/Walkera 22e so that it doesn't move? I've tighten the flybar holders, which keeps it from sliding in and out but it's twisting. Do I need a couple drops of glue it to the flybar holder?
I just got another Eagle50 and noticed this one has the 4-in-1 mounted below the purple metal frame and my existing one is above. Which way is better or does it even matter? Thanks.
I can't answer your question , only pose one of my own and point out an issue i had today. BE sure to use your little allen wrench and tighten the collars on the main shaft. I did not check them and they came loose today and now my swashplate is separating and my main motor does not turn. I even took it out and it won't turn without load either. I was also wondering if anyone knew if I can upgrade to metal parts are ony other models parts compatible???
