T-rex parts usable on the Dragonus II
[sm=spinnyeyes.gif] Can anybody tell me if the T-rex 450 head will work on the Dragonus II? Are any of the parts interchangeable for that matter?
cw-racing
cw-racing
CA
RE: T-rex parts usable on the Dragonus II
Yes you can use the head with 120deg swash.You should also use Align main shaft which will require drilling for one-way sleeve and pulley bolt.
Then you have to make up a rear antirotation bracket.
I've read that the new two piece Align main gear and hub will work but have not tried it myself.The reason for swapping would be because the Align gears are cheaper than the stock ones and maybe a little better quality.
VA
I believe the old SE spindles will also work. I think they are the same size. I have to pull my spindle soon so I'll know for sure in a day or 2
CA
I bought an Align hub and gear and it will work.To get the right gear and belt pulley alignment you need to press the oneway a mm beyond top of the hub.
