piccolo separates!!! help!!!!
TX
heres the specs
stock fun piccolo
pg-03 gyro
ics 50 esc for tail
ics 100 for main motor
naro 6ch receiver
when i have everything connected the first time it all works the way it should (sort of)
if i unplug the battery and replug it in. the servos work but either the tail motor on the main doesn't work.
BUT if i switch off and then on my tx a couple of times then they work!
haunted?!
can somebody shed some light?
it's getting me so frustrated i really wanna sell the pic.
thx for any replies.
ps please reply to my email: [email protected]
stock fun piccolo
pg-03 gyro
ics 50 esc for tail
naro 6ch receiver
haunted?!
NC
The GWS ESC's need to see the throttle at full off before they will arm and start working. Make sure the throttle is full off before applying power to the receiver/esc, then after waiting for the gyro to stabilize, and with the throttle still off, move the rudder stick full left for a second or two. If this doesn't work, then you may have to adjust the endpoints on your transmitter, to make sure the ESC's see both the throttle and rudder channels at zero.
Jeff
Jeff
He's right, you have to have your radio on and throttle at zero and rudder trim to neutral, then wait until the light comes on for the second time on the piccoboard. Then you can push the rudder stick and see that the tail moves, then push your trim to where you want on the rudder and you're set to fly.
