trex 450 v2 6 months vid
CA
sorry for vid quality were having camera woman issues still lol
anyway been flying for 6 months out in the front yard, ill try and get a better vid shortly
http://www.youtube.com/watch?v=dZXsQRCcV4s
CA
RE: trex 450 v2 6 months vid
trex 450 V2, frame and main gear.
cf boom
gorrilla gear, struts and paddles [full weights in paddles] believe it or not
maverikk tail belt
tail weight mod
scorpion -8 V2 and align 35x esc
hs 65mg,s and a 9257 on the tail
copterx V2 alloy tail and head
kong power over a 100 flights
lipo was not fully charged if you listen you will here it powering down [esc kicking in and out] for lipo protection
cf boom
maverikk tail belt
tail weight mod
CA
drilling holes and tapping them in the tail blade grips, then adding 4 servo linkage steel balls.
if you go to helifreak and do a search for it and or chineese weight mod or firups weight mod
FL
Pretty decent for 6 months. You were running a little too much gain that day, if you don't already know, as the tail pitch can be heard oscillating at times. How many minutes do you get before you hear the ESC pulse the power?
FL
i would really like to do the mod. but i still don't get it. where do i buy the parts needed and how do i do it? it seems like all the pros are doing this mod.
And why on god's green earth havn't the manufactuers implemented this design into their helis?
FL
Model helicopters haven't evolved enough to be perfect just yet. Control feedback on the tail due to centrifugal force is an area that will surely get more attention by the kit designers in the near future, now that the Chinese weight mod has become common knowledge.
CA
321 the gain is fine any lower and the tail blows out with hard collective. i normaly get 4:30 flying and leaving plenty left in the lipo. apparently it was not fully charged before the flight as thats i believe what you can hear at the end of my vid. the esc was cutting out rite at %20 left in the lipo [ i set it that way for lipo longevity].
noob there are company,s making tail blade grips with weights built in. like 321 says they dont have this stuff perfect thats are job lol
FL
thanks for the heads up 321. i do have the trexsev2 metal gear case and metal tail rotor grips (uninstalled) all i need is the tail slider that broke during the last crash. i also have the metal head for my trex that is ready for install. i didn't install these items yet cause i see no reason to yet. but if doing this mod makes my trexsa fly better than i will defintely install them.
CA
keven at helifreak [fireup] sells the kit if you have a metal tail. the kit comes with a jig for the drilling, a tap and a drill bit for $20 shipped. the mod is a must when you get into hard collective while in reverse flight. my tail would blow out in hard reverse loops but now its rock solid and i can get away with murder on the sticks lol. its almost exactly like flying my sim now. if i can do it on the sim my heli will do it that day just the same.
FL
thanks SR. this will be my next project then. i will order the parts and work on it. the cool part is that i already have the metal tail uninstalled and it won't affect my fly time with the rtf trex.. see....those extra parts are paying off.
FL
hey SR. check out these tail blades.
http://us.st12.yimg.com/us.st.yimg.c...9_2008_9288418
are these the same as the tail mod?
