Blade 400 setup
PE, CANADA
Hey, I just bought a Blade 400 and I am planning on using it with my JR 6102 Radio, I have a few questions. When setting it up, there is no menu for gyro sensitivity, the manual says it at
0: 70
1: 70
Do I just leave it?
Also, for throttle hold it says
ACT: Hold Pos.
Hold SW: 0.0%
Do I just ignore the Hold Pos aswell?
And last question, For the flight mode switch, which position is normal mode and which is idol up? I think that forward is normal mode but I'm not sure.
0: 70
1: 70
Do I just leave it?
ACT: Hold Pos.
Hold SW: 0.0%
PE, CANADA
In 6102 it does not give any indication which position is which
Edit, Figured out which position is which.....just need to know
how to set throttle hold to hold position.....and how to adjust sensitivity to 70.....i think you do it in sub trim menu, here is an excerpt from horizon hobby.
The JR 6102 transmitter is somewhat different in that it does not have a “Gyro Sensor” mode. The remote gain feature will be accessed by using the sub-trim adjustment function. It will be necessary to use the Gear (retract) channel. First set the Gear reverse switch to “N” and travel values to “0” for both (+) and (-). When you enter sub-trim values for the gyro gain the mode will be selected as follows:
* Tail Lock Mode – Sub-Trim values from +1 to +125
* Rate Mode – Sub-Trim values from –1 to -125
* No Gyro function – Travel value of 0%
