exi 450 pro review
RE: exi 450 pro review
Thanks allot noobflyer, I guess aslong as the heli goes up when you move the stick forward and down when you pull back than I can't see where it really matters or does it? I was mistaken about the servo it is the one directly behind the rotor head. I think if I shorten the link there I will be able to adjust the other two so that the swashplate is level. Do you just eye ballit or is there a better way? I have all my servos at 90 degrees and need to figure out where to start the frist linkage so I can level off the swash. As far as the pitch set up I don't know ratter Iwill use1 or 2 option above.
Thanks again for the fast responce and advice. I can post some pics as soon as I figure how to do it.
