Eolo TR vibration fix tip!!!
MA
EOLO TR vibration tip!
Hey guys I installed the robbe fix kit and it did help alittle with the vibration but It still vibrated in the TR.
what I did then was I took off the boom and saw that the TR drive wire guides in the boom migrated together so I fixed that by putting on a thin layer of tape to make a tighter fit in the boom , and the vibration was better, but it still vibrated some through certain RPMS...what I did next was to install a 3rd drive wire guide part # 5101....smooooooth as glass!!!!!!!!!!!!!!!!!!!!!!!
very nice no more TR vibes, I'd suggest if you do this mod do NOT equally space the 5101 in the boom and make them fit tighter so they don't move inside the boom
good luck
Jeremy
www.rchover.com
good luck
Jeremy
www.rchover.com
