help with setting up jr xp6101 for heli
CT
I need some help setting up my heli with the Jr xp6102. From what I understand this radio is very simple. I under stand throttle curves, pitch curves, subtrims, idle up and normal mode pretty much everything.
My question is on my travel adjustment feature, the gear setting is my gain on my gryo?
it says high 100 and low -100, and it wont let me change the value of the low, so is it suppose to stay at -100?
also I am very confused on what switches and locations I should put where, as far as idle/normal mode switch, gear switch, etc
If someone is using this radio, could you post all you settings, so I can mirror them and go from there.
thanks sooo much
thanks sooo much
