RCU Forums
-   Electric RC Helis (https://www.rcuniverse.com/forum/electric-rc-helis-167/)
-   -   I CANNOT TAKE OFF..PLEASE HELP!!! (https://www.rcuniverse.com/forum/electric-rc-helis-167/1389091-i-cannot-take-off-please-help.html)
waynepj3 12-30-2003 04:00 PM
hello all,
I am new to RC helis and now own a Hummingbird Electric. The problem is when I throttle up the Heli first vibrates then begins to spin but WILL NOT TAKE OFF. It won't leave the ground one inch.
Also, I start with the throttle stick/right stick in the down position and slowly move it up to gradually increase thrust/rotor speed. But when the stick reaches the half way point or so that it is pointing straight up the engine just stops??!! Is this normal?? How do I adjust this???
Flying Weasle 12-30-2003 04:53 PM
RE: I CANNOT TAKE OFF..PLEASE HELP!!!
Sounds like a dead battery. Stopping when it gets below 5 volts.
Make sure the fly bar paddles are lever and flat. And lever to eachother.
waynepj3 12-30-2003 05:10 PM
Hmmm...are the flybars supposed to be loose? If not..how do I tighten them??? No visible screw.
